cupped lower control arm trouble?? 69 c10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2012, 07:14 AM
Hey guys, i have a 69 c10 and just got done cupping the control arms to drop the front a few more inches....every little bit helps!
I know this mod has been done numerous times, so I wanted to see if anyone could shed some light on my situation.
I got the cup cut and plate welded in last night and wanted to make sure everything fit up. If I had been thinking I wouldve tack welded first then checked but, like I said I have seen this mod tons of times. I cut the desired amount out of the ca's from pictures of other members who have also done it with success. Rookie mistake!!
I got the bag centerd in the lower cup to make sure it didnt rub, it looked good! I purchased a pair of upper plates from suicidedoors bolted them up and raised the lower control arm up to check alignment.......and the bag sits back about an 1 1/2" from the top lining up with the bolt holes!???
I redrilled the top plate to align it, but it just bothers me tha it doesnt line up properly?
I have no idea why its not lining up? If anybody has done this mod and can point me in the right direction Id really appreciate it!
Old 12-19-2012, 09:45 AM
You need to make sure your alignment is with the bag at ride height.
globlewest lower control arm racecartom Suspension - Brakes - Steering 0 03-01-2012 09:12 PM
68 GTO lower control arm removal adam83 Suspension - Brakes - Steering 14 02-13-2011 12:58 AM
lower control arm bolts helrazr3 Suspension - Brakes - Steering 3 07-09-2007 07:10 PM
Lower Control Arm 71 c-10 Suspension - Brakes - Steering 2 03-29-2007 12:08 PM
73 vette lower control arm bushings tam5892 Suspension - Brakes - Steering 2 07-25-2006 08:47 PM
