Curing Lamps for Powder Coating Applications - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-05-2011, 09:42 AM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
31Vicky, that is an excellent breakdown. I couldn't have asked for a more simpler explanation. You've clearly know your stuff. Thank you so much!
powderbill, thanks for sticking around this thread in case we have any more questions.
Hey Matt,
Originally Posted by matts37chev
i have heard of guys building a metal 4 sided box (top and 3 sides) that fits onto the front of the oven so they can use it with the door open for bigger parts
Thats interesting. I would think it would be a five-sided box to keep the dust and cold air out.
what powder coating system are you using and how well do you feel it works?
this is something i have wanted to start doing for a long time
i had a guy, but he sold his business, and the new owner, after some very bad experiences (long story) could'nt pay me to coat my stuff
I am using Eastwood's Elite HotCoat Powder Coating Kit. To me, it seems like a good starter kit with the gun, some basic colors, plugs for holes and a guide book. I have only used it twice but I feel it works well. I have powder coated a set of wrenches and a carburetor and they came out pretty good, in my opinion. The system has very good reviews online as well.
The system isn't difficult to use at all. As long as the compressor is up and running, the gun is properly grounded on the part and there isn't too much powder in the bottle, things go rather smoothly.
Now that I am considering doing things like valve covers with the raised letters in different colors that the covers and whatnot, I am having to learn how to properly mask parts and properly cure the two different colors.
One of the things I have not figured - and I hope someone can chime in about it - is how to powder coat a part that is hanging from the wire, but the wire is covering a part of it. This is not a problem if the wire is in a place where the part won't be coated. But for something like wrenches, there will be that small section that won't be painted because the hanging wire is on top of it.
  #17 (permalink)
Old 06-05-2011, 05:48 PM
31Vicky's Avatar
Wire blinding part of the part
What you have discovered is called the"fariday cage"effect. What this means is this-powder coatings are electostaticly applied. You put a charge on the powder and ground the part so the powder is attracted to it. The powder will take the shortest path to grounded metal, which in you example is to the wire leaving a blind uncoated area behind it. Only way to avoid is to hang part different.
curing lamps, home shop tools, oven, powder coating
Powder Coating alcher14_82 Hotrodding Basics 13 04-13-2008 06:15 AM
curing lamps coupe33 Body - Exterior 6 01-01-2008 06:03 PM
Powder Coating chuckbell8 Introduce Yourself 2 11-04-2006 09:25 AM
Powder coating pepi General Rodding Tech 14 09-29-2006 07:40 PM
powder coating stea Body - Exterior 2 11-26-2004 12:22 PM
