curious about supply and return lines for fuel injection - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2005, 08:09 PM
all show, all go with a 383
I'm going to be converting a carbureted motor over to injection, but I was curious about something.
I read from an article in Carcarft.com about installing a ramjet fuel injection, that it is better to run a smaller supply line ( -6 ) and then run a larger return line ( -8 ).
Has anyone ever heard this before? Because people I now that have fuel injected motors all told me to run -8 supply and -6 return lines.
Please let me know, any information is helpful.
Thanks
Dan.
Old 10-02-2005, 08:23 PM
ronb's Avatar
[QUOTE=novadan]I'm going to be converting a carbureted motor over to injection, but I was curious about something.
Thanks
Dan.[/QUOTE the return line is usually(should be) the smaller of the two!
Old 10-02-2005, 08:48 PM
Pantaz's Avatar
Just remember the supply line has to provide enough flow for full-throttle, max-power. The return line is simply a bypass to bleed excess fuel back to the tank.
