curious, anyone ever build a heavy truck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2012, 07:01 AM
I just bought a 07 sierra 2500 ext cab short bed 4x4 with a 6.0l
it needs a new engine and I was kicking around the idea of building a fast DD out of it. (built motor, turbo, etc)
Curious how much power it would really take to get one of these to move and be able to hit 10's or so. Figure the 4x4 would help to launch but the damn thing weighs around 6-7k, so its not light at all.
Old 09-14-2012, 07:48 AM
unless you got deep pocket that are topped off in $100 bills i wouldnt try and make a 10 sec truck out of that. those trucks are heavy and to get it to runs 12's is a pita, the biggest problem is to make the kind of power to run that, street-ability goes out the window gas mileage will suck horribly and the and the trans upgrade to run that are very expensive your best bet to have a 10 sec truck is sell that get a duramax or cummins or newer powerstroke get efi live spartan any real agressive tune turbo upgrade and supporting mods and spray the hell out of it.
ill put it in perspective my old cummins dually 2wd ran solid 13's on street tires although with sticky tires i would have hit 12's(2.6 sec 60') and that was with a hx40 boosting 42lbs, 4k gov spring 20* timing head studs full cut delivery valve tuned afc, 4k into trans work and a few other mods. what was awesome about the truck was the fact it beat my neighbors g37 consistently around town and still got 20 mpg empty
Old 09-14-2012, 09:51 AM
vinniekq2's Avatar
You could build a 1500 hp turbo l.s. engine.The driveline parts would not last long.
Old 09-14-2012, 11:26 AM
Banned
I second most of this post. Doing it with a gas engine will be much harder and more expensive. If you want to get a 6.0L truck into the 10's I'd drop a 6.0L into an old datsun truck, luv, s10, ranger, etc. something under 3,000 pounds.
Old 09-14-2012, 10:48 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Your only hope of getting it in the 10s is massive money... engine, tranny, rear, suspension... wow.
Trade it for a duramax, do a chip, intake, exhaust, and turbine housing, and you'll be squarely in the high 11s and get 24 mpg.
Old 09-16-2012, 03:36 PM
Replacecment fuse block for 1978 GMC heavy truck dwb812 Electrical 1 09-05-2012 04:16 AM
Own 1981 Silverado 1/2 ton heavy duty pickup truck haystacksmama Introduce Yourself 2 10-21-2010 01:46 PM
How is this build for a heavy car? sbchevfreak Engine 8 12-06-2006 02:51 PM
57 chevy truck - heavy chop / section / shave - photoshop lowROLLERchevy Hot Rod Art 1 02-05-2006 08:02 PM
heavy truck trans question propaniac Transmission - Rearend 7 09-08-2004 01:48 PM
