Current draw-how much is too much? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2005, 05:54 PM
My battery was dead (8v.) after sitting for 2 days so I recharged to 12 v.& did an amp test inline with the positive battery cable. On the 10amp scale it only showed .01amps with everything off. Is this normal or should it be absolute zero??
Old 07-30-2005, 06:26 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
depends
Depends on options. A clock or radio with clock will draw power. So will an alarm system. Other options can draw power when the car is off as well. I generally use a test light instead of an ammeter.
Old 07-30-2005, 06:57 PM
No radio, no clock ..not much really as its a '49 PU with later mustang running gear though it does have onboard compressor for the air ride suspension. I don''t think it draws unless needed to maintain tank pressure though.
Old 07-30-2005, 07:15 PM
A .01 amp draw will not drain a battery in two days. You need to disconnect your pump and see what happens (besides truck taking a squat).
Trees
Old 07-30-2005, 08:19 PM
Last journal entry: frame build
.01 isn't even into surface leakage. Did you check the batt water level? If ok or uncheckable, charge the batt at 10 amps for 20 minutes and do a load check on the batt. It should maintain 12v for 10 seconds.(average test time) If it doesn't your batt is about to take a squat.
Old 08-02-2005, 04:17 PM
docvette's Avatar
Wiki Edits: 12
Cells
Doc here,
If you got a cell reading below 11 volts at anytime, you have a bad cell (s) Replace the battery..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
427 or 454? frankenvette Engine 50 06-05-2005 11:12 PM
Fan Switch on the Ground Leg? JohnTN Electrical 8 05-15-2005 09:35 AM
Elec. fuel pump relay needed? upstand2 Electrical 4 05-10-2005 06:21 AM
What is the normal current draw? Bryan Munday Electrical 3 01-27-2004 01:47 AM
