"Curving" power window tracks - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2004, 12:05 PM
New Member
I'm looking for a power window kit I can install in my 65 Corvette. The doors were completly gutted by the prior owner so installing an original "lift arm" style system isn't an option. I've been looking at the various units shown in Street Rodder. I have two major issues for an installation:
1) I only will have about 3" from the bottom of the glass to the bottom of the door when the window is down.
2) The lift rail would need to be curved (in the thin direction) to have about 1 - 1 1/2" of bow over it's 15" length. You can see the amount of curve in the window run for the other door laying across the bottom.
Now for the questions: Which kit has the lowest clearance required (I'm assuming the remote motor kits take less room at the bottom of the door); and has anyone tried to curve the lift track? I've never seen a unit in person so am not sure if I could curve the lift track (which I can do easily) and not have the slider bind (which I have no clue).
Thanks - Greg
Name:	door inside.jpg
Old 12-13-2004, 03:18 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Ouch! Off-hand I can't think of any of the mechanisms used in the after-market systems that would be curve-able. My first approach would be take a trip to the junk yard to find a unit that could be adapted. One of the cable operated ones with an already curved track sounds doable at first blush.
Old 12-13-2004, 07:24 PM
Last journal entry: Disaster
Honda Accord (I know 2001) window tracks are curved already.
They use a clean cable system that might work.
You can by the whole system track+motor on ebay for $50.
-alfie
Old 12-13-2004, 08:13 PM
New Member
Thanks for the tip. I'll try to see if I can locate one to look at.
-Greg
