Custom Aluminum Fuel Cell Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2007, 04:26 PM
chevy3600's Avatar
http://community.webshots.com/
I ordered this custom tank from alumiworx. Dave the owner was supposed to have included a sending unit with the tank. When I got the tank it had no hole for a sending unit. It did have 3 1" OD holes (fuel outlet, fuel return, and vent) and one 3" hole for fuel intake. Any suggestions on how to proceed here? Do I need to have a machine shop make a hole for the sending unit? Where do I get a sending unit that will work for this size tank? Any help will be appreciated.
Old 12-22-2007, 06:52 PM
You must match the sending unit to your fuel gauge ... ohms to ohms
Sending units come in different lenghts and are hung right or left. I would determine which fuel gauge I was going to use ... how many ohms the range ... the depth of my fuel tank and then cut the hole to match the sending unit ...
Go here for a better explanation ... it is a page from the Speedway Motors catalog.
http://www.speedwaymotors.com/p/7850...0fuel%20sender
I had to do this same thing on my original 32 Ford fuel tank ... Nothing to it
Old 12-23-2007, 07:30 PM
boatbob2
fuel guage.......
hi,napa has a nice adjustable sending unit,with its own guage,about $35.00,works great.,lay the gasket on the tank,magic marker the inside diameter of gasket. take a hole saw and cut the size hole you need.use a vacum cleaner as you cut,and then take a piece of 5/8 in dia hose,tape it to vacum hose,and clean inside of tank. drill 6 holes using gasket as a template,and youre good to go,
Old 12-23-2007, 08:26 PM
31 five window
Last journal entry: Moving along with patch panels.
Doesn't he owe you one? Make him send it to you.
Old 12-24-2007, 06:27 AM
chevy3600's Avatar
"Doesn't he owe you one? Make him send it to you."
You're right, and ALUMIWORX may do that, but in the meantime I am making plans on what to do if he doesn't. Believe me if he doesn't come through I'll let everyone on this board and all the other boards I'm a member off know about it.
Old 12-24-2007, 07:34 AM
31 five window
Great, but if he doesn't all you need is a hole saw and drill bits. I was a Johnson outboard mechanic for 20 years and they are the same in boats. I have installed many custom tanks and fuel senders. As someone said just make sure the sender matches the gauge.
Old 12-24-2007, 07:40 AM
31 five window
Also if you do install it yourself notice most have 5 unevenly spaced screws,so make sure and line up the sender float arm in your tank before drilling holes.
Old 12-25-2007, 08:35 AM
Dugg's Avatar
My compass doesn't point North
Hey Deuce,
Very nice looking chassis.
Old 12-26-2007, 01:28 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
I custom build a lot of fuel tanks. I get my sending units from Classic. You do have to match the sending unit to the gauge. Ohm readings. Most all of them use a 1 1/2" hole and I just use a hole saw to put it in the tank. Those sending units are universal and will work with most any size tank.
http://classicinstruments.com/
If I can help you out let me know.
http://cgi.ebay.com/ebaymotors/10-ga...spagenameZWDVW
sbc fuel line problem jw4413nv General Rodding Tech 8 12-22-2006 03:11 PM
Fuel Cell Foam or not Scoops Engine 2 01-23-2006 04:39 PM
Fuel Cell Problems Stupido1 Engine 5 08-13-2005 08:17 PM
custom floor and fuel cell 16grem72 Interior 1 02-08-2005 02:30 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
