Custom brake brackets - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2012, 12:18 PM
Mutt's37Buick's Avatar
I'm currently planning on buying CPP 30101 drop spindles for my project , but I want to adapt it to work with 12" brakes and rotors with my donor car ('95 Roadmaster).
I'll need to have a sleeve machined to adapt the bearings and need to have a custom bracket machined (or laser cut) to hold the calibers.
1) Has anyone bought CPP brake brackets 5870DBK (see attached) that can tell me the thickness of these plates?
2) Does anyone know what metal the are made from (I'm guessing zinc plated steel)?
3) Does anyone know if a part like this would need to be heat treated?
Thanks for your help
Veresailles emergency brake brackets likaroc54 Suspension - Brakes - Steering 1 06-02-2006 05:02 AM
Disc brake brackets for Ford 9" fearsomefairmont Suspension - Brakes - Steering 2 05-11-2006 07:11 PM
Scarebird brake brackets.... poncho62 Suspension - Brakes - Steering 9 05-09-2006 06:34 PM
Custom Bumper Brackets VWFan Body - Exterior 1 10-07-2005 02:59 PM
brake brackets Jeff46 Introduce Yourself 0 06-22-2004 06:29 PM
