Hello
I recieived a reply to this post, but it does not look like it is showing up I centerd the engine and the rear end is a narrowed Dana. The car has been back halfed with custom 2x3 mandrel bent frame rails I have R@P steering, so I am not using any of the original mechanism I have thought of unbolting the two halves of the calipers and mounting a flat aluminum plate on the back, so in essense the calipers are now only two piston. The brkts will be modified to allow the calipers to float( I am a tool and die maker so I can fab stuff up) I already purchased VBP calipers which where not cheap. I think even a factory two piston will have clearance isues with the rim I had not really heard much back on this, so I kinda' already started the modifications.........hopefully it works take care Tom |
Hydroboost Systems
I Posted A Long Winded Answer, But It Was Deleted.
another edit....by the Moderator....because of SPAM........ BoB ...you have been warned......... This is your last warning.....
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| Dual Master Cylinder Brake Pedal with Balance Bar | iceman36 | Suspension - Brakes - Steering | 6 | 02-24-2006 12:55 PM |
| 65 Galaxie brake system | carpenter125 | Suspension - Brakes - Steering | 1 | 04-21-2004 12:29 AM |
| ?? Flushing Brake System | Cliffrun2 | Suspension - Brakes - Steering | 9 | 03-12-2004 09:02 AM |
| Should I keep my hydro-boost brake system? | drlindz | Suspension - Brakes - Steering | 3 | 09-11-2003 09:38 PM |
