custom cab mounts ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2012, 04:01 PM
custom cab mounts ?
i am about to do a custom s10 frame under my 50 chevy coupe. any ideas or plans or pics or any help on making a cab mount? looking for a simple idea as to im new to the whole custom fabricating
Old 10-10-2012, 04:13 PM
Wow, new to fabricating? You have bitten off a HUGE project. The body mounts are the easiest part. You would place the body into position and build the mount up to the body, that simple. Trying to make the mount using measurements off the old frame "could" be done but not knowing exactly where the "new" frame may hit under the body and that sort of thing there is no way I would try that.
Honestly, this is a HUGE job which will require a LOT of fabrication and cutting up the inner fenders and rad support. This is before you do things like mounting bumpers which are another project.
It's like the old engine swap lingo, people will ask about the mounts, making the mounts as if THAT is all that is needed for an engine swap, the mounts are the easiest part. Often the complication comes in the firewall clearance, rad location, rad outlet location, steering box clearance, steering column, exhaust/headers, there are a PILE of stuff that may need attention for a "simple" engine swap. Same is true changing a frame.
Tell me, what is wrong with the old frame? There are PILES of kits available to upgrade that frame that require no fabrication, or little fab so you can get your feet wet. And remember, that frame you have under that car, it's the same as a 53-62 Corvette, it has the exact same suspension (rear springs are different is all) as the Corvette, so it isn't "that" bad.
By the way I am looking to buy one of those front crossemembers to use in my truck if you want to sell it. Isn't that funny, I am going to upgrade my 48 Chevy pickup with the suspension from a car like yours.
Old 10-11-2012, 05:49 PM
yea it is a big project. something ive always wanted to do. figure with some friends and help it may take me a long time but i will get it together. frame is shot. rusted apart really. pulling it onto rollback was difficult for frame breaking. bottom side of frame has tons of rust on it. frame really isnt salvageable. so that why im starting with frame and going from there
cab mounts and springs 46highboypu Suspension - Brakes - Steering 0 11-02-2010 10:43 AM
Making cab mounts indyracer Body - Exterior 0 04-15-2006 09:07 PM
'40 Ford Pickup cab mounts alittle1 Hotrodding Basics 5 04-03-2004 06:41 AM
Cab mounts Gearhead forever Body - Exterior 7 01-28-2004 10:38 AM
86 s-10 vibration cab mounts bad? catscan4free Body - Exterior 4 01-26-2004 03:23 AM
