Custom carpet in trunk. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2012, 07:40 AM
Last journal entry: Body work
I'm to the point in my build that i need to figure out how to finish the trunk before I install the fuel cell and the other hardware.
I would like to carpet it but can't get it to a shop and don't have the ability to sew at home.
This is a first for me so any input is appreciated.
Thanks
Old 01-23-2012, 12:35 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Start with the side pieces that are vertical and flat. Make patterns for each section leaving them a little large, and then one at a time, fit the pieces in and glue them down, bumping them up to each other snugly. You will need to use a high temperature contact adhesive to glue the pieces in place. Once all the individual parts are glued in place, you can start on the bottom of the trunk. I usually start with a piece larger than needed, weight the carpet down in the middle to hold it in place, and then fit it into the corners and mark the straight cuts on the back of the carpet. You might want to make a pattern for this section also, instead of trying to fit it free hand.
Old 01-25-2012, 06:58 PM
Thanks for the info Dan.
Your the man.
Old 02-01-2012, 08:18 AM
gow589's Avatar
the Clever Turn Signal
Here is how I did one. I cut flat boards then just glued carpet to the boards. The boards are modular and removable. The back wall is actually held on with magnets. Use poster board to make template:
Old 02-02-2012, 06:28 AM
67Mustang Al.'s Avatar
Mg
Nice MGB you have there. I had a 68 MK 1 some decades ago for about 16yrs.. The colour was similar to yours called Champion Red.
The boot interior was bare so your carpet will add a bit of class and soundproofing.
Cheers
al.
How to carpet my trunk lid/deck Longboard Interior 2 10-10-2010 09:32 AM
DIY custom carpet americanLT1 Interior 1 08-22-2008 01:50 PM
Custom trunk Derkyb Interior 4 08-08-2005 07:15 PM
Door Sill Plates and Custom Carpet JhnBrackett Interior 7 07-04-2005 11:21 PM
Trunk Carpet Kits JoeS Interior 5 03-06-2003 10:34 PM
