custom dash - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2006, 08:28 PM
dboyett38666's Avatar
custom dash
Hey I have a 77 camaro,and I was wanting to make a dash out of sheet metal,what I was wondering is should I by a pre-bent dash from Jegs or some where like that,or should I make a card-board template,and have some one bend it for me.How thick should the metal be?Any help on this would be very appreciated.Here is a pic when I first bought the car,looks a little different now.
Name:	donnie's car 007.jpg
ID:	12152   Click image for larger version
Name:	donnie's car 004.jpg
Old 05-14-2006, 07:37 PM
raidmagic's Avatar
Last journal entry: Studebaker
I just sold a 72 Camaro that I made a custom dash using the stock piece as my template. It's much cheaper to do it yourself even if you have to get a sheetmetal shop to put the bends in it for you.
Old 05-14-2006, 08:15 PM
Thanks you dont happen to have any pics?What size sheet metal did you use?I was wondering if some-one on here has made a dash for these cars.I know it can be done thanks for posting
Old 05-16-2006, 07:39 AM
raidmagic's Avatar
I used 1/8" sorry I don't have the car anymore so I can't provide pics. I just brought my trim piece to a local sheet metal shop and asked them to bend me a piece in that shape. I then cut it and put the gauges in it and polished it up.
Old 05-16-2006, 08:57 AM
Thanks I will start on it soon I hope
Old 05-16-2006, 09:53 AM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
1/8" seems a bit thick (.125") to work with if you bend it yourself. You could use something like .060" (about 1/16" thick) aluminum if you are doing inserts. You could use it for everything if you brace it properly. Steel is nice but harder to work with. There you could use .040-.060" steel for the whole structure and it would be perfectly sound. The only problem with the steel is it rusts. Rust proof it real well on the backside so it will last. If you had a factory dash to cut up it would save a lot of effort in making the mounts fit right.
Old 05-16-2006, 10:05 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
0.060 works fine and since you had no dash to begin with the sky is the limit..build what you like..
Sam
Old 05-16-2006, 10:42 PM
Thanks for all the replys.
Old 05-17-2006, 02:28 AM
check this out
http://www.fullsizechevy.com/forums/...ghlight=jimmyp
Old 06-22-2006, 05:57 PM
Last journal entry: 65 Gal glass console completed
bending sheet metal
For bending sheetmetal you can use anything round and press it around. For making tighter forms maybe make something like this out of a pillowcase and some sand. http://www.eastwoodco.com/shopping/p...&keyword=28045
Old 06-22-2006, 11:19 PM
black66's Avatar
www.airriderz.com
dash
I made a custom stainless steel insert for my six six Impala
Dave
Old 06-23-2006, 06:44 PM
oh yeah
Dave that is the kind of thing I am talking about. Please give a blow by blow because I can't follow what you did just fromn the pics. But even so. it is a nice result.
My work in progress custom dash: advice needed. friday General Rodding Tech 6 12-31-2010 01:20 PM
fully custom dash Ozgood103 Interior 5 11-30-2004 09:17 PM
custom classic dash Ozgood103 Introduce Yourself 1 11-17-2004 01:58 AM
custom dash install pintoperformance Interior 4 10-31-2003 12:30 PM
custom dash for 76 dodge power wagon lelag Interior 0 09-01-2003 06:30 AM
