Custom Dash Layout for 48 hot rod.. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-19-2007, 12:48 PM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
The mock up looks great!
When you build the pieces you may want to tilt the center section along the vertical axis 1/16-1/8" towards the driverside to make reading the gauges easier...just a thought
  #17 (permalink)
Old 01-19-2007, 06:21 PM
PRO 48 fleetline's Avatar
Last journal entry: Csr Electric Water pump
Thanks a good idea but looking to make it a center justifcation for a simple clean look,
and will be using a 5" gauge with the four gauges water amp etc in the console to motior the big motor and still have a simple look, aswell the air ride controls will be hidden thanks for the input love al kinds of cool ideas lol later
  #18 (permalink)
Old 01-20-2007, 11:26 AM
Next part to work on is opening the top of my hood the frnt is molded and is in flip form now but going to open it up like an early mercury have to brace in inner structure and open the hood and than a new radiator is order; any suggestions on a good radiator to hold up to close to 600 hp looking at a griffin alumin now or even a be cool, thanks GP
Name:	frnt bumper mock up 070.jpg
ID:	17839   Click image for larger version
Name:	frnt bumper mock up 118.jpg
ID:	17840   Click image for larger version
Name:	frnt bumper mock up 121.jpg
ID:	17841   Click image for larger version
Name:	frnt bumper mock up 007.jpg
ID:	17842   Click image for larger version
Name:	frnt bumper mock up 072.jpg
  #19 (permalink)
Old 01-20-2007, 11:53 AM
I think the only "problem" you might find with the placement is reading the gauges accurately...or are you going to use digigtal gauges?
I've driven CJ5's for years and the analog gauges are center mounted on a flat dash...but the gauge layout is designed such that it reads correctly only from the drivers position I'd think they were taking into account the angle of the view.
My Hudson also has center dash mounted gauges from the factory (w/2 glove boxes!) but I'm replacing the analogs with LCD's and digital gauges and adding a rotating Heads Up Display...
  #20 (permalink)
Old 01-20-2007, 12:59 PM
No im not running the digitals was going to but going to keep an older theme to the interior but by making my own speedo for the center in larger number form like the stock 57 truck but with my own font and, keep in mind im not building a daily driver lol and alli want to be visible is the speedo in the center and plan on running a borgeson cup style tack on the column real old school looking with matching tan face to speedo 5" gauge will be in console to montior engine, but with set up with seats and seating position it will be justttt fine lol
Hot rod builders wanted- Western N.C. WoodsEdge Hotrodders' Lounge 16 11-13-2013 02:47 PM
Beverly Hillbillies Hot Rod tgotcha Hotrodders' Lounge 19 05-09-2013 10:50 PM
What will be your next Hot Rod? 78SilverShark Hotrodders' Lounge 72 06-28-2006 08:48 PM
cool hot rod custom culture shops writer Hotrodders' Lounge 6 05-14-2005 10:10 AM
Need Hot Rod and custom paint shop in Phoenix AZ. Truth Speaker Hotrodding Basics 1 04-10-2005 09:02 PM
