Custom Ford 9" Rear Build:
I'm building a 9" rear for a drag car and want to make sure I have all the parts here @ time of build. I know I'll need axle & pinion bearings, gaskets, and a solid crush sleeve. Here's what I have so far:
Housing Tubes Tube Ends Axles Studs 3rd Member Case Pinion Support Yoke Spool Gear Set Ring gear bolts Pinion Nut Anything missing? |
To the top...
how about a bearing set for all that cool stuff?
Asside from axle and pinion bearings...sorry about that.
Solid spacer on pinion. If you can attempt to use two halves of a spacer with your shim(s) in the middle of the two halves. This will keep the shims from wearing down and opening up tolerances. Shim material is kinda weak. Seals?
56Maynard: Sounds like something to look into, for sure. I've never heard of that
Mustangsaly: The diff. for this app. is a spool. |
| i got ford parts on my chevy rear axle | roy383ci | Hotrodders' Lounge | 0 | 09-11-2005 03:31 PM |
| 9" conversion for 48 ford rear end | big mal | Transmission - Rearend | 1 | 08-23-2005 09:47 PM |
| ford rear end | jay1 | Introduce Yourself | 1 | 09-18-2004 03:29 AM |
| Whatever happend to these guys? | hot_rod_kid | Hotrodders' Lounge | 20 | 12-17-2002 09:20 AM |
