Custom gas caps - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2005, 09:07 PM
Blackdog's Avatar
Custom gas caps
I bought some "Cool cap!" gas caps from Air Ride Technology. I'm installing the first one in a 1976 International Terra. This vehicle originaly used a non vented cap.The stock vapor canistor is in place. The filler neck, like most vehicles has a vent hose near the cap. The new cap offers no way to vent like the original did. The tank is vented to the canister. So the question is, what do I do with the original vent hose that use to go to the top of the filler neck? Thanks
Old 09-10-2005, 09:15 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Leave it. I think that is an anti-belch port more than a vent port.
Old 09-10-2005, 10:48 AM
Blackdog's Avatar
Problem is there is no way to hook it up. I could install a port lower on the filler neck but I think that would be too low.
Old 09-10-2005, 03:03 PM
Wiki Edits: 21
Too bad. That is a nice feature to have so gas doesn't belch out as you get top off the tank.
gas prices 69novarodr Hotrodders' Lounge 27 04-17-2009 09:47 AM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
Need Tank Sender for Custom Gas Tank.... bg Engine 3 11-05-2002 05:13 PM
Which Gas tank is Best?? HotRodMan Engine 1 09-06-2002 09:19 PM
priming for 1st start w/new gas tank required? bullheimer Engine 4 08-09-2002 07:05 AM
