custom grind cam specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2013, 12:35 PM
Fang16's Avatar
Last journal entry: Project change
These numbers look right for a blown 6-71 sbc? Follwed F-birds instructions but not sure of the readings. Suppose to be a custom grind but the numbers on the end don't tell me who made it. May be a custom grind from Comp Cams but haven't heard back from them.
LSA 115
Intake Centerline 112
IO 25
IC 82
Intake lift .336, max .504
Exhaust Centerline 118
EO 82
EC 67
Ex lift .341, max .512
Intake duration 287
Exhaust duration 329
overlap 92 degrees
Old 05-31-2013, 02:04 PM
techinspector1's Avatar
Wiki Edits: 326
Blower Drive Service, the Roots blower guys who have been in business for decades, has told us that the best power on gasoline will come from a 110 lobe separation angle. They say that a wider angle may work better on alcohol, but you need to tighten it up for gasoline.
Read through their recommendations here.....
http://www.blowerdriveservice.com/recommend.php
Old 05-31-2013, 02:30 PM
Banned
110 regardless of the rest of the combo? I would call a good cam grinder and talk to them they should set you straight. There is no magic lsa, it's all application dependent.
Old 06-01-2013, 07:02 AM
Fang16's Avatar
Originally Posted by F-BIRD'88 View Post
based on your timing numbers this cam is on a 108LSA. It is very retarded. 118in 97 ex c/L's based on the
valve timing.
Not a blower cam.
What is this? something you are reading? Something you measured?
I measured it using your methods. I done it till the numbers were duplicated, that's not to say that I didn't have something wrong. It's in the blown sbc I bought from a widow. I found some other questionable things in there too. The numbers didn't seem right, That's why I asked.
Old 06-01-2013, 08:19 AM
Fang16's Avatar
Measure the open and close timing points @ .050" lifter rise.
Be sure to find true TDC using a piston stop to set the degree wheel first.
Use a solid lifter when degreeing, or if using a hyd lifter set up the dial indicator on the edge of the lifter body, not the plunger.
Is this a flat tappet cam or a roller cam?
what are all the numbers stamped on the ends?
Hyd lifters-flat tappet
Numbers are:
B4686, 5447 129 H34, H11464 and either a 3 or backwards E, kind of a squigglely thing.
Here's the method I used which I got from this site. Tech Inspector I think?
Note that the readings are at .006"
You have a short block there. Attach a degree wheel and go through the motions, just like degreeing it in the first place if you were building the motor.
I know you know how to do this, but I'm gonna outline the procedure for others who don't have the knowledge.....
Procure a piece of round steel, 1.000" O.D. by 12" long. Chuck it up in the lathe and turn the O.D. down to 0.841"/0.842, then cut it off about 8" long and finish both ends flat and smooth. This will be your checking tappet. Those of you who work on different makes of motors can make this checking tappet Chevy diameter on one end and another diameter on the other end for checking cams on a different motor. With the block tilted on the engine stand so that the bore of one bank is straight up and down, your checker tappet will follow the cam contour easily due to its weight. Set up your dial indicator on the other end of the checking tappet by using a magnetic base on the block deck.
First off, on a SBC, the front (forwardmost) tappet hole for #1 cylinder is the exhaust tappet. The intake tappet hole is second from the front of the block adjacent to the #1 cylinder.
Find top dead center on the #1 piston, either by using a positive stop bar across the bore (best way) or by using your dial indicator on the piston crown as you swing the piston through several degrees each way from what you perceive to be top dead center. With the piston at TDC, zero your degree wheel with your timing pointer (can be as simple as a piece of clothes hanger wire coiled up on one end to attach under a bolt head and sharpened to a point on the other end).
With the dial indicator on the intake lobe for #1 cylinder, roll the crank clockwise to the highest reading on your dial indicator. This will occur somewhere between 100 and 115 degrees after top dead center going clockwise and will be your intake centerline.
We'll say this point was 106 degrees ATDC. Write it down as "IC-106".
Roll the crank counter-clockwise until you are off the lobe of the cam and the dial indicator is no longer retreating. Zero the dial indicator. Now, come clockwise on the crank until you are showing 0.006" tappet rise on the indicator. Let's say this occurs at 38 degrees before top dead center on your degree wheel. This is the intake opening point at 0.006" (also called "advertised") tappet lift. Write it down as "IO-38".
Roll the crank clockwise through TDC, on around to BDC and a little past until the dial indicator again shows 0.006" tappet lift. This will be the intake closing point. Let's say it occurs at 70 degrees after bottom dead center. Write it down as "IC-70".
With the checking tappet on the heel of the lobe, zero your dial indicator. Roll the crank clockwise until you get the highest reading on the indicator. Let's say it's 0.375". Write it down as "Intake lobe lift-0.375". Multiply the lobe lift times your rocker arm ratio to find valve lift. (example 0.375" times 1.5 equals 0.5625")
Now, re-position your checking lifter into the exhaust tappet hole and set up your dial indicator. Run the crank through a cycle or two to get the highest reading on your indicator. Let's say this occurs at 114 degrees before top dead center. This is the exhaust centerline. Write it down as "EC-114".
We can now determine with this information, what the lobe separation angle of the camshaft is. Add the intake centerline (106) to the exhaust centerline (114) and divide by 2. We find that this cam is ground on a 110 degree lobe separation angle (LSA). Just to make it all the more confusing for you, the LSA is also called Lobe Displacement Angle or Lobe Center by some.
Turn the crank until there is no movement on the indicator and the checking tappet is on the heel of the exhaust lobe. Zero the indicator. Turn the crank clockwise until you observe 0.006" lift on the indicator. This will be the exhaust opening point. Let's say it occurred at 78 degrees before bottom dead center. Write it down as "EO-78".
Rotate the crank clockwise through max lift and on down to where the indicator is recording tappet lift of 0.006". This will be the exhaust closing point. Let's say that this occurs at 30 degrees after top dead center. Write it down as "EC-30".
With the checking tappet on the heel of the lobe, zero your dial indicator. Roll the crank clockwise until you get the highest reading on the indicator. Let's say it's 0.375". Write it down as "Exhaust lobe lift-0.375". Multiply the lobe lift times your rocker arm ratio to find valve lift. (example 0.375" times 1.5 equals 0.5625")
Now, you have all the information you need. On the intake, you add 38 and 70 and 180 and find that the advertised intake duration of this cam is 288 degrees.
On the exhaust, you add 78 and 30 and 180 and find that the advertised exhaust duration of this cam is also 288 degrees.
You know that the intake centerline is 106, the exhaust centerline is 114 and the lobe separation angle is 110 degrees.
You can add the intake opening to the exhaust closing and find that the overlap at advertised cam timing is 68 degrees.
Old 06-01-2013, 05:15 PM
Fang16's Avatar
when measuring @.006" the oening and closing side are very different and you are much more prone to a error.
Measure again but at .050" lifter rise. if your checking lifter does not have the very slight convex face you will get a slight error.
But the .050" numbers will show you what cam it is.
You can also repeat at .200"
from this you will find the cam lobes and cam LSA etc based on the .050" timing numbers,,, not the points of max lift.
On a modern non symertical cam lobe these will be different.
Again, the relevant specs are @ .050" and .200" lifter rise open/close.
Thanks for the info but I'm not clear on what the .200" reading is for.
Old 06-02-2013, 11:15 AM
Fang16's Avatar
Cam lobe libraries include a duration @.200" helps you define the cam lobe and
tell the difference between lobes with the same .050" duration and lobe lift.
with the .050" duration and .200" durations and the lobe lift you can find the cam lobes.
Great big thank you coming your way! Been trying to find what cam I have for over a month. Your info did the trick.
Old 06-03-2013, 06:04 PM
Fang16's Avatar
So, what are the measured .050" and .200" cam timing specs, Now...?
if the cam or any of the 16 lifters are showing any wear at all,,do not reuse.
Measurements, numbers on the end of the cam and the cam log link and a call to comp cams showed it to be a NX284H. (over kill? lol ) All the lopes n lifters look great. Now if I can get the block level I'll cc the cylinder. Ideas? It's on a engine stand. Here's some pix of the pistons. Any idea what they are and who made them? They're forged, didn't notice any manufacters ID when I had the block turned over to look at them. They are at TDC so an educated guess at cc would be great. Looking for 8-8.5 CR with 72 cc heads altho lower would be nice.
Please note that I'm handicapped and can't just roll the engine over. Many years ago when I was young and didn't need it I had an engine stand with a geared crank on it. Haven't been able to find another one.
Name:	2013-06-03 17.46.17.jpg
ID:	74596   Click image for larger version
Name:	2013-06-03 17.46.55.jpg
Old 06-04-2013, 03:28 PM
Fang16's Avatar
The don;t look like forged pistons to me. Look like a stock replacement ,,,maybe Badger or.... (Not really important)
fine for moderate boost 8-9psi or less with low compression and modest timing. as long as detonation is avoided.
The piston is not highly stressed unless detonation is present, on a street blower motor.
Measure the dish volume by measuring the depth and diameter of the center dish. Add 4cc to 5cc for the 4 valve reliefs to that ..
a "rebuilder piston"
Probabily .045" below deck @ TDC. not a problem.
You can measure the true volume of the piston (dish with the valve reliefs) by setting the crank so that the piston is a convient way down the bore ...say .100" using a dial indicator. then get some common Vaseline and wipe it around the piston bore edge to seal the piston rings. to be water tight. The vaseline seals the piston in the bore. Don;t be shy ...Now Get a old CD ROM disk to cover the top of the bore. Use common Vaseline to seal the CD disc to the block deck. Fill the cylinder with water and find the filled volume of the cylinder with the piston .100" down the bore from TDC.
Note this CC volume. use a shop vac to vac out the water in the bore. The vaseline won';t harm anything.
oil wipe the now dry bore. Now measure the piston to deck clearance @ TDC (.045" ish probabily.)
Tell me these two figures. I will calc the cr for you , with a 72cc head and common .041" gasket.
You can buy a 100ML graduated cylinder (glass or plastic) from many local pharmacies. Go the the counter and ask.
100ML='s 100cc
The piston is likely -15cc (estimate)
The engine compression ratio is probabily between 7.98:1 and 8.27:1 depending on the measured piston deck clearance @ TDC....060" bore 4.166x.041" gasket 72cc chamber head.
Are you freshing up this engine or just want to see what is in it? The .060" cast dish pistons are fine for moderate street supercharger use. Do not sweat this.
Piston ring end gaps should be generous (large) don't be shy on the ring end gaps. Bigger is better.
.026" to .032" is good. Use normal rebuilder rings ( Hastings are fine) and hand file fit the end gaps.
You do not need fancy parts. Just parts that are not already wounded,, and correct assembly.. The blower makes the power.
The piston sees a bit more heat load when under boost. The large generous piston ring end gap keeps the piston from ring butting (broken ring lands).
Again the piston are not stressed unless detonation is present. That is avoided by correct engine tune up. (timing/jetting boost retard////low compression ratio) These pistons will make all kinds of supercharged power.
The cam is fine. Do not mix up the lifters. replace if any hint of wear.
But I prefer using a solid lifter cam in this type of motor. Up to you.
I came up with .049 down in the hole and a cc of 46. What can you see from these pix of the bottom end. It shows some of the piston and some of the crank. I can't find anything on either one to ID them. (not a photog either)
Forged or not?
I got it from a widow and want to know what I have before doing anything with it. It still has cross hatching in the cylinders. I keep the lifters in order in a lifter holder from summit.
Name:	2013-06-04 13.04.43.jpg
ID:	74624   Click image for larger version
Name:	2013-06-04 13.05.11.jpg
Old 06-04-2013, 03:29 PM
Fang16's Avatar
These XE Comp cams need good valve springs.. What heads are on this motor?
How do you plan on using this motor in a car?
Either AFR 210's or RHS 200's with comp cam springs. Street and strip will be it's use.
Old 06-05-2013, 07:11 AM
Fang16's Avatar
and a cc of 46
Where was the piston. in the bore for this. ??? .100" from the top of the bore or was it at .149" from the top of the bore. (.100"+.049")???
I get a -15cc dish .049" piston deck clearance @ TDC 4.06" bore 4.166x.041" gasket 72cc head
engine cr ='s 7.93:1
It was .100" down from TDC, messured at the center of the piston. Sorry, didn't think of that. Set it at TDC, zeroed dial Indcater on block, slid over to piston center, .049, zeroed Dial Ind, turned piston .100" down hole.
Old 06-06-2013, 11:09 AM
Fang16's Avatar
measure the deck clearance again. You did it wrong. Measure with the piston @ TDC but measure from the highest part of the piston. not in the center of the dish.
Now what is the piston to deck clearance @ TDC.?
this is the same piston. measure the deck height @ TDC from the highest part of the piston. ( the outer ring part, not the dish)
Then: what is the diameter and depth of the dish of the piston, only..
I know what the valve relief volume is already. just need the correct deck height clearance and the dish dimensions.
so the piston was .149" down the hole instead of .100" down from TDC....right.
46cc @.149" makes sense .but is not the spec I am looking for..... .100" piston lowered down from TDC should be 36.2cc poured measured water volume.
measure TDC from the high point on the piston. then lower the piston in the bore by .100" Then fill that with water using the4 CD rom and vaseline grease. Should be real close to 36.2cc ( no water leaks )
Redone it the right way, lol, and it was 36.1 cc. Happy with the numbers now. Thanks for all your help!
What all do I need to do to get a custom grind from comp cams? eric32 Engine 4 06-09-2009 09:07 PM
vortec cam selection, custom grind? slate84 Engine 12 02-04-2009 10:02 PM
Lobe separation for nitrous on custom grind Lunati TorkMonster400 Engine 12 06-29-2008 04:00 PM
what companies grind custom billet camshafts ? lowROLLERchevy Engine 16 09-01-2007 04:18 PM
Which companies custom grind camshafts? batman09 Engine 17 01-31-2005 12:32 AM
