custom headers ford 351W - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2011, 06:25 AM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
for a street '67 mustang with a mild 351W should I fabricate headers with 1-1/2 or 1-3/4 primary pipes? how long should they be?
I own a muffler shop and I can fabricate headers but never done any project like this so I have no clues, there is no 1-5/8 pipe available here so I'm limited to 1-1/2 and 1-3/4 diameters.
what would be a good collector size?
the down pipes will be 2-1/2 with an X crossover and 2 glasspacks.
Importing stuff from the USA is very expensive over here, this is why I won't be buying already made headers, besides it's more fun DIY.
thanks
Old 04-11-2011, 09:10 AM
JeffB's Avatar
Since you have 1 1/2" & 1 3/4" I would fabricate the Tri-Y headers like in this Pic,these fit 65-69 Mustangs 289-351, collectors are 2 1/2" these produce strong low and mid-range power.
Name:	tri-y header.jpg
Old 04-11-2011, 09:52 AM
Augusto's Avatar
very cool, is the pipe arrangement compatible with the 351's firing order?
are those pipes 1-1/2 or 1-3/4 ?
thanks
Old 04-11-2011, 07:44 PM
ericnova72's Avatar
More for Less Racer
You could also fab a step header, come off the head port with 8-10" or so of 1-1/2", then continue on with 1-3/4" down to the collector. Step headers have become very popular here in the States, helps to broaden the powerband by increasing low end torque.
Primary pipes 32-36" long, with 3" collectors 18" long.
Old 04-11-2011, 08:38 PM
Augusto's Avatar
that's a good idea also, I use step headers on the motorcycle engines that I use to power the single seater off-road buggies that I build, they perform great and sound very well, I have also made them in 3 steps, 1" to 1-1/4 to 1-1/2 or 1-1/2 to 1-3/4 and to 2", depending on the engine used.
Old 04-12-2011, 12:02 AM
JeffB's Avatar
The primary "Y" shaped tubes that come off the flanges are 1 1/2" and connect into the two 1 3/4" that flow into the 2 1/2" collector.No problem with the firing order.If you Google "Mustang Tri-Y headers" you will find a lot of info and pictures online you can use to help fabricate them.
Old 04-12-2011, 08:27 PM
Augusto's Avatar
thanks a lot, I'll spend a few hours on google, thanks God for the internet
Custom install an 02 sensor in headers? kpcrossfire6 Engine 4 03-31-2011 05:22 PM
custom headers scoundrel57 Engine 6 07-18-2007 10:56 PM
making custom headers??? aztek_warrior Engine 2 07-11-2006 10:13 PM
Cost of custom fabricated headers? TwistedDragon Engine 20 11-28-2005 11:44 PM
Headers for 351w in a 1963 fairlane FAIRLANE DUDE Engine 1 10-28-2002 10:19 PM
