Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Custom Headliner for '36 Ford Pickup
Old 02-15-2012, 10:17 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Ordinarily, I would mount a 1/4" base of luan plywood just under the roof of the truck and mount the headliner board to that, but with the top chopped, I couldn't really do that because there would be no headroom left. I decided to just use 1/8" PVC foam board, do the design on it, and mount the board in the truck by itself. I hung a piece of chipboard to the roof of the cab with magnets, so I could measure the size of the headliner board from that. It turned out that 48" wide was going to work, and about 36" from front to back. I also planned to bend the foamboard with heat, and use the rear bottom of the vertical part to mount the back of the headliner board to the frame of the truck just above the rear window.
ID:	62976   Click image for larger version
ID:	62977   Click image for larger version
ID:	62978   Click image for larger version
