Custom Impala bumper - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-06-2013, 04:24 AM
astroracer's Avatar
Don't be shy about using "other" materials to make the shapes you want/need. I used 2", 3" and 5" diameter muffler tubing to make parts of the bumper I built for my truck. The rest is 10 and 16 gage steel.
I will be going thru this same process when I build the bumper for my van project.
Go ahead and weld on the front. Grind it down to get the welds smooth. Shy away from brazing if you are going to plate it. Brazing "works" different then steel and it will leave a shadow that you will see after plating. It is impossible to polish the two materials together and get them to be at the same "surface", if you know what I mean.
Mark
  #32 (permalink)
Old 05-06-2013, 07:34 AM
Mark
Mark, you are absolutely right! I have never used brass for this and didn't have any advice but the simple fact that the brass is softer than the metal would make "surfacing" it equal very difficult!
  #33 (permalink)
Old 05-06-2013, 12:27 PM
I know this doesnt help much but I think no matter which one you finally go with/fab worked flipping it upside down would look real good. With the curviture of the rear on each side with the bumper flipped it would give the whole rearend an hour glass look.
Custom bumper. ehsankiani Body - Exterior 3 04-24-2006 02:59 AM
Custom Fiberglass Front Bumper for SN95 Mustang OurLady Body - Exterior 0 02-23-2006 01:48 PM
Custom Bumper Brackets VWFan Body - Exterior 1 10-07-2005 01:59 PM
1965 impala bent bumper help? impala65 Body - Exterior 2 08-22-2003 07:50 PM
removing bumper 1964 Impala matt_ramsey Body - Exterior 7 06-24-2003 02:15 AM
