Custom LED tail ligths, how to bundle led's? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2009, 06:16 AM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I want to build some custom tailigths for my 46 chevy, my idea is to arrange them in a mold and pour clear resin to bundle up the whole thing.
I need help to learn how to connect the led's, do they work in series or paralel or mixed or what?
is there any limits of how many can be connected together?
do I have to add a ballast resistor to drop the voltage to what, 3 volts? or what is the voltage needed for this things?
do they make yellow led's? I have found red and white already but not yellow.
is there any website about this matter, please help me.
Thanks.
Augusto.
Old 03-03-2009, 08:37 AM
302 Z28's Avatar
LED's are wired in parallel. You can hook almost an infinite number of them together as they draw very little current. Most all LED's for automotive use are rated for 12vdc. If you choose LED's of lower voltage rating you must drop the supply voltage down to their requirements. There are also hi intensity LEDs that are perfect for automotive use. As far as I am aware of they are available in clear, red, green, blue, and yellow. Here sre some sites that carry LEDs.
Mouser Electronics
Digi Key Electronics
Both sites do not have minimum order requirement and both have excellent web sites and paper catalogs.
Vince
Old 03-03-2009, 11:45 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I did some 6v LEDs where I did two in series to share the voltage, but it didn't work very well. Little variances in the resistance of each one meant they drew different currents.
Stick with 12v LEDs and put them in parallel.
Old 03-03-2009, 12:30 PM
You might want to poke around on this site for info.
http://www.superbrightleds.com/led_prods.htm
Paul
LED tail lights stay partically lit cboy Electrical 20 07-21-2007 07:59 PM
Home made LED tail turn brake crownver Electrical 2 02-19-2006 06:46 PM
Custom Tail Light lens 39deluxe General Rodding Tech 4 02-06-2006 01:49 PM
custom LED's cornfieldcars Body - Exterior 23 07-14-2004 06:17 AM
Custom tail lenses Mav Body - Exterior 5 05-12-2003 04:17 PM
