Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Custom lower control a-arms for 1937 Buick
Old 01-16-2012, 01:33 PM
Mutt's37Buick's Avatar
Mutt's37Buick Mutt's37Buick is offline
So here is a new approach I'm exploring allow the front suspension upgrade:
http://www.crankshaftcoalition.com/w...ension_upgrade
The roadblock that I ran into is that there are no lower control arms with balljoints that I have found that match the dimensions of my '37 Buick Roadmaster (see sketch). The wiki is focused on coupes that have 18" lower arms.
I have considered having a balljoint mount plate welded onto the existing arm.
I have considered making a transition plate that is bolted, or welded, to the frame to attach a shorter arm (probably a Chevy C10 truck lower arm).
Another option may be to have a custom lower control arm built that matches the current geometry.
1) Does anyone have a company they would recommend to build a custom lower control arm?
2) Which approach do you all think will have the best results.
Thanks
Mutt
Name:	005 '37 Buick, Front Suspension.JPG
File Type: pdf Arm Sketch, 1937 Buick Roadmaster, Lower.pdf (29.9 KB, 141 views)
