Custom Paint Stenciling - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2004, 04:31 PM
I Plan On Painting My Car With BC.CC I Also Made Some Stencils For Custom Picture On The Side Whitch I Plan On Spraying With Black How Would You Suggest Putting The Stencil On The Side Of The Car So The Design Gets Sprayed Correctly?
Thank You For Your Advice In Advance
Old 06-11-2004, 11:20 AM
New Member
What are you using for a Stencil?
Where in Iowa are you?
Old 06-11-2004, 12:04 PM
in Desmoines
you know posterboard right know ive got a big design drew out on it i wanted my own custom design if i should do it on something else i can redraw it though
ok its an 86 iroc the stencil is kinda big about 75 inches long...
not to mention behind the door theres a piece that goes up it goes up that too.... i have really no idea what it should be done on....or how to put it on for that matter....when you cut out the part that should be painted all the other spots that aint are gonna fall out....guess ill have to tape all them to the car also...
Old 06-11-2004, 12:43 PM
New Member
Go to a sign shop and see if you can get some application tape it's like masking tape but 6" to 48" wide.
apply it to your car and cut it out.
Do you have a pic of your design? You might be able to use masking tape.
I'm just south of ya in Indianola
Old 06-11-2004, 12:48 PM
lemme hook up the cam...masking tape will take 12 hours on each side....
im not seein the wire to hook it up ill keep lookn though....lets put it this way
the design is well big....
theres a Demon Lady comn off the front of the rear wheel well a shot of her from the tummy up and her head goes onto that little spot beside the windows then her mouth is open and flames are comn out of it with a demon skull towards the front fender flames all the way to it ...and in the middle of the flames right smack on the door is Iroc-Z writtin in bones...... i guess maskn tape would work just gotta b patient to use it
Old 06-11-2004, 01:02 PM
New Member
is the design a solid graphic? or are you going to airbrush it?
Old 06-11-2004, 01:40 PM
air brush would be best the guy said to get it on the car and and just mix the black put it in the air gun and spray its not all solid just outlined
Old 06-11-2004, 04:36 PM
could i use contact paper or would that mess up the paint? id peel the contact paper off after spraying the car...then clear coat...
Old 06-12-2004, 08:12 PM
ok then contact paper it is unless someone says that a bad idea...
Old 06-13-2004, 02:08 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Do not use contact paper. There is a product called frisket paper and should be available from art supply stores.
http://www.arttalk.com/artv1109-6.htm
http://www.hobbylinc.com/htm/bad/bad601.htm
http://www.top-flite.com/reviews/trimgraphics.html
Kevin
Old 06-13-2004, 02:17 PM
Marcel
Last journal entry: Choo-choo town
the paint job
Hey guys, why can't he do this the way they did van with the pictures on them. I don't know how it was done or with what, but they sprayed the picture with something, then peeled it off and put it on the veh. then clear coated over it to seal it.
Old 06-14-2004, 08:27 AM
New Member
My vote is still transfertape
If you use concact paper get the light adhesive and don't leave it on too long.
I'm not sure if frisket will handle the solvents it my melt.
Old 06-14-2004, 10:22 AM
BOBCRMAN@aol.com's Avatar
Lanierledford, That was called "Acrylustration" I used to do a lot of it back in the seventies.
You pick a subject. Poster, picture, drawing etc. Then you spray it with several coats of acrylic (clear) paint. When set up, the original picture paper is washed off the back. This results in a very thin decal. This decal is then sprayed on the backside with acrylic clear (slow reducer) and then transfered to the fender that has also been prepped and shot with acrylic clear (slow reducer). You have to be quick and accurate or you will have a big mess. But it works. I started out on tool boxes with Vargas girls from Playboy mag. Then gradually got into complete auto hoods etc. The paints available now are better so I would think the process would be easier and longer lasting. As the early stuff suffered from excessive film build and the cracking and UV. weathering over the years of exposure to the elements.
Old 06-28-2004, 02:55 PM
i have an 89 camaro
and i was wondering what all kinda stuff you have in urs to make it look pimp...
i'm gettin a paint job on mine where it fades from the front as blue and then gradually turns to black by the back of it
Old 06-28-2004, 05:48 PM
its getting painted wednesday the painter had family problems ill take pics when its done and ill be sure to post them im me at Aces0vr8s 0 = zero and ill be more then happy to send you the pics then i figure thursday ill have the pics developed and scanned
