Need Way More Information.
By crossover steering do you mean like a vega style? What steering box are you using?
Welding pitman arm
Now I know there will be a lot of teeth nashing about this but it is totally possible to weld a pitman arm. I would never recommend doing it but the way to do it is to get a pitman arm that is the same type as the one you would want to use. Cut the end off the one you want to use and grind the ends to a point and cut another piece that is of similar thickness and cut it to length and bevel both ends to a point preheat the arm and the insert to a color of straw and t.i.g. weld the piece so the arm is longer. Make sure to keep it straight. Make sure to get the weld all the way through even if you have to grind in from the opposite side from where you are welding. Weld the whole thing till the weld is thicker than the arm. Sand the arm in the length ways direction to relieve stress risers. Heat the arm till a pale blue color and wrap it in fiberglass insulation (about 6" worth) let cool for a day or so. Tou will never be able to bust this thing in a million years but we cannot weld suspension parts so you are outa luck ...
How long is your crossover steering arm on the top of the knuckle?
How long is the pitman arm? How much drop do you need the pitman arm to have (if any)? I'm using a 70's ford van pitman arm on my 71 k5 with crossover steering. It has enough drop to clear my frame (about 2" of drop) and is the right length to get full steering. Your steering box should have the same sector shaft spline as the 2wd truck steering box that I'm using. I had to re-taper it to fit the larger GM tie rod ends that I used. I got the tapered reamer from xkut on ebay. |
pitman arm
Price is correct. I've seen older welders, stock car and custom car builders shorten/ lenghten/ repair forged steel parts. The old timers slowed the parts cooling time by packing the just welded part in sand.
Warning this is off topic to the question asked. This is just a rant: There was ingenuity, creativity long before it became common place to hand someone wads of cash to build/ assemble store bought parts for thier custom, street rod, race car and then have the gall to say look what I built instead of the truth look what I comissioned. Very few people have the talent or time to completly build thier project but to say I built this in my opinion one should of at least assembled at least 80% of their vehicle. This is what is cool about this site eevryone is doing thier best at building their own ride. |
I have made a few pitman arms. Take a pitman arm that fits the box and cut off the splined end that fits the shaft. Cut this piece round. Now take a piece of 1/2" x 2" steel bar and make a hole in it so that the old pitman arm end will fit in this hole. Grind as needed. After you get it were you need it weld it real good on both sides and just let it air cool. Bend this arm as needed. You will have to heat it with a torch or have acess to a big press brake. On the other end I used a heim. But you can drill a hole and ream if you need a taper.
I made quite a few on old straight axle gassers back in the day. |
| 4" drop pitman arm for 85 chevy 3/4 ton | punk1c5040 | Suspension - Brakes - Steering | 1 | 01-01-2007 05:04 PM |
| Header Clearance Issues with Pitman Arm | k2mooch | Suspension - Brakes - Steering | 4 | 04-26-2005 01:35 PM |
| pitman arm installation help?? | fireforsin | Suspension - Brakes - Steering | 4 | 08-11-2004 01:13 PM |
| bad pitman arm? | 69elcaminoss | Suspension - Brakes - Steering | 8 | 03-02-2004 12:44 PM |
| pitman arm clerance | tack | Suspension - Brakes - Steering | 3 | 03-16-2003 09:04 AM |
