custom shackles - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2007, 03:52 PM
custom shackles
I just installed a Ford 9" in my 1965 Falcon. The original rear end was for the 6 cylinder car and it still has those leaf springs. The problem I have is with the larger axle tubes, the car sits about 2" lower in the rear. I have been unable to locate modified shackles to raise the car back up. Anybody know of anyplace that sells them??
Old 11-26-2007, 04:41 PM
Jr 1948
Last journal entry: frame painted and motor is in
Hey find shackles for something with the same width of leaf spring would probelly work
Old 11-26-2007, 05:01 PM
31 five window
Last journal entry: grill and rear end
Longer shackles are available through JC Whitney,but they really look bad from the back.Try air shocks or coil spring kits that go on your existing shocks.JC Whitney usually has these,also NAPA used to offer them.
Old 11-26-2007, 05:09 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Make your own.....just cut some flat steel stock the right size to length and drill some holes in each end.
Old 11-26-2007, 07:00 PM
leldai73's Avatar
Its just metal,you're the boss
just lower it 2 inches in the front to match?
Old 11-27-2007, 10:04 AM
custom shackles
Thanks to all of you for your replies. At least I now have some info to research. Thanks again!!!!!
2007 Rod & Custom Americruise 2007 pictures posted wp442 Hotrodders' Lounge 2 07-04-2007 12:59 AM
cool hot rod custom culture shops writer Hotrodders' Lounge 6 05-14-2005 09:10 AM
Winfields custom shop IROC100 Hotrodders' Lounge 7 01-21-2005 11:20 AM
custom avatars are ready Jon Hotrodders' Lounge 18 06-21-2003 04:06 PM
