Custom Shift light - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2005, 08:53 PM
Derkyb's Avatar
Custom Shift light
I'm building a custom shift light using high intensity LED's and a MSD RPM activation box to trigger the circuit. Question: Has anyone wired up more than one LED in a series/parrallel circuit? How should I wire the circuit with the MSD switch?
Old 11-05-2005, 02:50 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
The easy way, is to go here, and get one of these...
http://www.msdignition.com/tc_13_rpm.htm
DOC
Old 11-05-2005, 08:47 AM
Derkyb's Avatar
Yea I could do it the easy way, but doing it the easy way wont make it unique.
Old 11-05-2005, 04:41 PM
docvette's Avatar
Wiki Edits: 12
Doc Here,
Well, just hooking LED's up in a series / Parallel arrangement isn't gonna get what you want either.
Not having the MSD diagram in front of me, but looking at the accessory product description, They provide a signal output and low (or ground ) to the lamp array.
At the Very minimum, and Not too accurate, you would have to measure the output there, as you reached your shift points.
Then , say your using 3 LED's Green 1, Yellow 2 , red 3, hook it up this way, the output directly to a Zenier diode, the green LED, say first shift point is 3 volts, you need to install a 3.1 volt (or there abouts ) So the LED remains off until 3 volts is achieved..then from that LED run another zenier to the yellow LED, Say it's shift point is 6 volts, Use a 6.1 zenier there, so it lights just after 6 volts..on the third say it's 9 volts..use a 9.1 zenier..This would give you an LED at each approximate shift point, but not shut down the lamp before it. Not too accurate at all...
To achieve accuracy, you would need an OP amp like a Bargraph chip for instance, this would provide an output for each individual shift light and turn it off after voltage is achieved..It would also provide a Null for adjustment of the shift points.
You could also use a TTL Divide by "N" counter like a 7490, and a seven segment decoder, your single input would be F/in, and low..have to run an external reset switch from the reset pin to get a "New Start" function, (or an over voltage loop for top end) you would then have to configure your counter jumpers for the best configurations for your app..Divide by 2 , Divide by 5, divide by 10 Ect..the output side would be on the seven segment decoder / Driver..each segment would light at a certain output from the Counter and shut down after, which would be each LED ... with the decoder, you would also have special functions, like "Dim/Bright" and Flash...
Or you could use Transistors, with a single input common, set to cascade at various shift points..(voltages)
Or an op amp VCo...
By Series parallel connection, I should think you'd get "All" or nothing at all" function at the LEDS..
Doc
Old 11-05-2005, 05:49 PM
Derkyb's Avatar
Wow You just gave me another idea about how to do this. I originally had just planned to use the MSD RPM activation module used to trigger any circuit at a specified RPM. Then wire the LEDS in an all or none fashion cause thats all you get with MSD lights anyway. Now I think I will use different color LEDS for each shift point.
Old 11-05-2005, 05:54 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
KEWL
Let me know what you come up with...
Maybe when your done, draw and post us a schematic ..always looking for home-brew stuff like this..as an alternative to store bought..
PLUS...It feels good to say.."I Did it"...
Doc
Old 11-20-2005, 08:11 PM
Derkyb's Avatar
Well this is what I came up with, decided to keep it simple and wire 8 superbright LED's in series/parrallel using two 220ohm resistors. I will use a MSD RPM activation switch to trigger it.
Overhead Courtsey Light Only Has Dime Glow JohnTN Electrical 3 06-07-2005 03:48 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
tach shift light probenit Hotrodders' Lounge 3 02-12-2005 05:11 AM
a little humor to get through the evening antirice Hotrodders' Lounge 7 08-28-2003 08:36 AM
Light problems Wmarden Hotrodders' Lounge 8 11-28-2002 04:55 AM
