Race cars use the smallest, lightest thing they can find......and as a general rule....no turn signals or horn button. I would just put bushings/bearings in the VW column...
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Here is a place you can find a VW column complete for cheap...
http://www.thesamba.com/vw/classifie...teering+column Or you can always check out the local junk yard... They usually have a few VW's laying around... I'd like to see your project, sounds like fun. Any pics? |
Well, it's still a Bug kind-of... More like a Bug on steroids! Did you build the frame yourself or is that a production unit? I would be interested in the plans you used....
If you would be willing to share... That thing should really go! Good luck and have fun! Bug on!!! |
I built the frame myself but used blueprints from the glass station, http://www.prostreetbug.com/ I hope the link works, otherwise google prostreetbug. The blueprints where very good and the frame turned out pretty square considering i dont have a jig or flat table. I bought a complete mustang II suspension from hiedts. the front suspension crossmember is a little wider then the front rails, but a little metal here and there and it worked out perfect.
Looking back i should have just bought a rear suspension kit from comp eng or something, but I felt like doing it myself. I have changed the panhard bar since those pictures to go stright across to the other side. The rear suspension took alot of thinking and i still dont know if it will work properly. The cage i bought from chris altsons chassis works ( i think that the name, probibly spelled it wrong) and it cost more to ship it then the tubes thenselves. I would have bent my own but i dont have a bender The width from the outsides of the tires is about 64", so th fenders will have to be widened. wheel base is still 95". I try to post some new pics, like my stainless keg for a fuel tank! |
| '39 ford steering column and wheel | jim williams | Suspension - Brakes - Steering | 5 | 07-01-2010 09:38 PM |
| Steering Column | grandprix601 | Interior | 17 | 03-08-2004 03:45 PM |
| Hotrodders Knowledge Cluster: Power Steering Conversions | Jon | Suspension - Brakes - Steering | 0 | 09-03-2003 11:20 PM |
| 34 ford steering column | vette66guy | Suspension - Brakes - Steering | 3 | 06-01-2003 07:04 PM |
| shortening the steering column | smoran | Interior | 3 | 05-02-2002 06:38 PM |
