Custom suspension 53 Chev P.U. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2003, 07:31 PM
Post Custom suspension 53 Chev P.U.
I would like information on stubbing front end from a chev Camaro or Chev Nova on a 53 Chev Pickup. What years match up the best? This is my first attempt at this so any information is appreciated.
Old 04-14-2003, 04:47 AM
jalopy45's Avatar
Cool
Both the Camaro and Nova sub frames require a lot of fabrication and the results depend on the installer. If done wrong the result will be a vehicle that dog tracks down the road, that just requires an 1/8 or less per side. (.125")You might consider a Mustang II setup that bolts into existing holes or a weld in unit. Check advertisers in classic truck magazines and look in the forums in this web site.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 04-14-2003, 05:32 AM
slider in wa's Avatar
Slider in Wa.
Post
Can be done, very easy, but time consuming. Ask Willy`s 33 about this as he has done many, more than i have.
Slider in Wa.
Old 04-14-2003, 01:09 PM
Post
Here's something that might help.
<a href="http://www.50chevy.freeservers.com/Subframe.htm" target="_blank">http://www.50chevy.freeservers.com/Subframe.htm</a>
