Custom Wiring A Hazard Switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2003, 08:14 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Post Custom Wiring A Hazard Switch
My steering column has no hazard button in it, so I didn't wire the Hazard Wire from the EZ-Wire kit to the column plug ... I left it hanging under the dash in the interest of wiring it to an independent toggle switch.
Question : How do I wire it up??? Do I just use a 2-pole switch with the hazard wire from the kit to one pole and a ground wire to the other pole? Or does it need to be tied in to the park wires somehow?
Thanks.
Alan Horvath
<a href="http://AlanHorvath.com/54chevy/" target="_blank">54 Chevy Pickup</a>
Old 05-11-2003, 08:35 PM
joes50's Avatar
Post
You just need a toggle switch. Wire the hazard wire from the kit into the toggle and the wire coming out of the toggle needs to tie into the front left and right signals wires and the back left and right signal wires so they all blink when the toggle is activated.
Old 05-11-2003, 10:15 PM
horvath's Avatar
Post
Aha! I get it ... THANKS, Joe.
Alan
Old 05-11-2003, 11:50 PM
akm akm is offline
Post
this might be a supid question but if there is a wire for the hazard lights wouldn't there be a flasher on the fuse block? if this is correct why would you have to wire it into the turn signal wires? wouldn't you just have to have a switch?
Old 05-12-2003, 05:49 AM
Limey Simon's Avatar
Post
Horvarth
Be careful with your wiring because if you link the Left (F&R) and right (F&R) onto a single toggle switch they'll always be connected and they'll all flash when you put left or right turn signal on (I know, I've done it). I used a hazard switch from an auto electrical store which has several terminals. The switch carries the feed to the normal turn signal switch, but CUTS this supply when you switch to hazards - and instead sends power to 2 outputs, one for left & one right. In this way your 4 turn signals aren't connected when you want them for left or right
Alternatively can EZ wire sell you an add-on to suit their wiring?
Limey
Old 05-12-2003, 09:13 AM
horvath's Avatar
Post
akm : There is a flasher in my fuse panel, and I thought the same thing you did ... but it blew a fuse!
Limey Simon : Thanks for that info, bro'! Makes sense ... I called some places locally and no one sells hazard switches ... then I called EZ-Wire and they don't sell one either ... but I found one at <a href="http://www.Wire-Works.com/" target="_blank">Ron Francis's Wire-Works.com</a> for $29.50 (gulp!) so I guess that gets me where I need to go.
Also ... I got instructions from a post at <a href="http://www.chevytalk.org/threads/showflat.php?Cat=&Board=UBB7&Number=430316&page=0& view=collapsed&sb=5&o=&fpart=1" target="_blank">ChevyTalk.org</a> for using a 3PST switch, but I'm gonna go with the hazard switch for simplicity sake.
Alan
[ May 12, 2003: Message edited by: horvath ]</p>
