customer wants a choppy idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2012, 08:37 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
okay here is the deal, a bit over a year ago a friends dad payed me to build a 355 for his mid 80's K-5 Blazer. he wanted to keep cost down then so here is what i built for him. he does not race the truck, just cruises around.
5cc flat top pistons (10.2:1), scat 5.7 rods, stock resurfaced 3.48" crank, dart 200cc platinum heads (i liked them when i had them), rpm intake and 3310 750 carb. the cam that i put in this motor was a new version of a cam that i had in my 383, 240/250 @ .050 .525/.525" with 110LSA. he wanted an estimate of how much power did it make and i told him about 420hp/410tq
the truck has 33x12.5 tires, built th350, 3500 stall, and 4.56 gears.
now he is saying that he likes the power that the truck has but that it doesn't have enough of a choppy idle, to make him happy i've even messed with the timing on this truck to see if i can please him but it's just not enough.
so he is paying me to build him a 383 now, he is on a quest for that magical 500hp number i can't say much, i've been there too. so what i have now is 12cc dished pistons, scat 5.7 rods, scat cast steel 3.75" crank which should put me around similar compression as the 355 (10.3:1). he wants to use the same 200cc dart platinum heads, carb and intake. i told him that we would have to fit the heads with new springs since he wants a roller cam, i also mentioned that i thought it would be a very good idea if he let me clean the ports up some. this will be my first time doing this myself, i've seen plenty of pictures, seen my heads after they were done and read the books so i think i can manage it, i'm only gonna clean it up some.
so after all this, here is my question: he wants a super choppy idle and i have given him the option of either having a hyd roller custom ground with these specs 244/248, .380" at the lobe = .570/.570" ground with a 106 LSA, or getting a solid roller cam with similar specs already ground. do you think that using this tight of an LSA will get him that choppy idle he is looking for? and do you think it's a better idea to use the custom ground hyd roller or the already ground solid roller.
Old 05-14-2012, 08:40 AM
Lopey cam that has no torque in a heavy blazer... not a good idea.
Old 05-14-2012, 08:53 AM
Banned
What exhaust and mufflers is he running? That'll probably satisfy his goals of sound. That cam is big enough to have a heavy lope but the mufflers make a hell of a difference in sound.
Old 05-14-2012, 08:54 AM
my87Z's Avatar
oh trust me i have gone over this with him over and over again, to the point of frustration. but "what the customer wants he gets". i told him that the 240/250 cam that i put in the 355 was more than i would recomend for the truck but that is what he wanted. he seems to be far more concerned with how it sounds then how the truck runs as total. and of coarse he wants to be able to say he has 500hp. i've told him that he wants the tq not the hp but his response is always "i want to pull up to a light with a nasty idle and have people looking" i think the truck sounds and runs great now, but it's not my truck.
Old 05-14-2012, 08:56 AM
my87Z's Avatar
iv'e mentioned that to him too, not sure what mufflers he has, i'll see if i can find out. i told him that it would sound good with the mufflers i have on my truck, the Thrush welded mufflers. but he isn't convinced that will get him what he wants.
Old 05-14-2012, 09:01 AM
cool rockin daddy's Avatar
Man, the guy trusts you to build the engine, you delivered the power he wants, but still won't listen to your recommendation on a cam. Man, that's a rough. If the mufflers don't do it, slap a Thumper in it and send him on his poser way. What else can you do?
Old 05-14-2012, 09:26 AM
my87Z's Avatar
he mentioned these to me and i told him that the big mutha thumer cam would have a choppy idle but then he wanted my opinion on them and how much power i though he would make with it and he didn't like what i told him. i just spoke to him and he says that he really wants to stay away from adjusting the valves so i told him that a custom hyd roller cam with the 106LSA was the way to go.
what do you guys think about this 10.3:1 383 with the DARt 200cc platinum heads and a hyd roller cam of around 244/248 .570/.570" with a 106LSA?
i know i wouldn't want it personally but, do you even think this will run on pump gas with that tight LSA
Old 05-14-2012, 01:19 PM
Banned
I think I wouldn't touch the engine until you knew it had good headers exhaust and mufflers. The wrong exhaust can make any engine sound like crap. I'd do dual 3" with the thrush welded mufflers and at least 1 5/8" headers.
Old 05-14-2012, 07:16 PM
my87Z's Avatar
well the truck has 3" duals with flowmaster 50 series mufflers (i told him he should change them) and it has headman 1 5/8" headers.
after i told him that it was going to cost him around $3000 for the short block, and complete valve train changed to roller, plus all the gaskets etc. he decided that was too much and wants to just go with the Comp Cams big mutha thumpr 299thr7 cam with the current 355 he has now. i told him that the comp cams kit for this cam was around $1100 and he would still have to pay to have the springs changed out etc. i estimated all this with gaskets, and new pushrods would be around $1500. i also let him know that in the end it wouldn't make any more hp/tq than it does now (likely less) and the only real thing that would change is that his pockets would have $1500 less and he would have a bit of a choppier idle.
oh i also told him that i wouldn't be doing the work for him, as i completly disagreed with his decision and didn't want my name attached to the finished product.
Old 05-14-2012, 09:12 PM
Yessssssss! Somebody with integrity and balls. I love it. I salute you sir!
Old 05-14-2012, 10:28 PM
Man If he wants some one to look at him in his truck at the light go headers with straight pipe and add a cross pipe to get the little loss of torque and horse back. that will get peoples attention at the light. Can always add resinator at the end of tail pipe area. Don't know about emmissions though Besides he needs more bottom end to mid torque and horse in heavy vehicle.
Old 05-15-2012, 01:23 PM
Pull a couple plug wires and screw up the carb adjustment, should idle just like he wants it to
Old 05-15-2012, 03:13 PM
Last journal entry: 27
yeaH!
my idea was to give him a cd recording of the sound of a dragster and tell him to buy a $10'000 stereo
he could play the cd at stoplights.
but your idea is even better
Old 05-15-2012, 10:42 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
toilet
put a toilet on it and run alcohol.
seriously
i've run everything from a comp .477 to a herbert .724
choppy idle to me seems to come from the exhaust system more than the cam profile
Why does the idle sound less choppy after installation of a tunnel ram? dasyhard Engine 24 12-29-2011 03:54 AM
will this cam have a choppy idle in a 355 jarrettandroski Engine 11 09-28-2008 12:26 PM
Another satisfied customer...so far redcamaro4spd Transmission - Rearend 0 11-10-2003 08:01 AM
Fleet Customer? asennad Body - Exterior 3 08-06-2003 10:50 AM
Customer service my *****! straight6nova67 Hotrodders' Lounge 10 06-10-2003 07:54 AM
