-   -   cut&buff help needed (http://www.hotrodders.com/forum/cut-buff-help-needed-224421.html)
cutthroatkid 09-27-2012 01:02 AM
I need help with how to cut&buff single stage paint.. a good link to a write up would be awesome as I can't seem to find much.Ok so here's the deal I just painted a buddys car&have lite orange peel that I was able to wet sand out fairly easy,but I have no experience in cutting&buffing I have a 7 inch sanders/buffer with foam&wool pads its the electric digital hf deal.I have no idea how to use this I have some medium mcquires forget What its called maybe cut&polish anyway its tan&have turtle wax swirl remover...What all do I need to buy &how do I give it some What of a shine Because now if just looks flat.Thanks fellas btw its a solid a/u
novafreek6872 09-27-2012 05:45 AM
I would recommend doing a you tube search and watching people actually use a buffer. Tons of great videos on there about it.
Also, it doesnt matter if its SSAU or BC/CC, it will still buff the same.
Take your time and stay away from ridges and edges. Dont run the buffer at high speeds and keep it moving all the time.
Watch some pros do it on video is the best advice I can give.
Andy
novafreek6872 09-27-2012 04:41 PM
I like this guy's vids. Pretty good place to start anyway...
Part 1 Color Sanding & Buffing - YouTube "> Part 1 Color Sanding & Buffing - YouTube " type="application/x-shockwave-flash" width="425" height="350">
cutthroatkid 09-27-2012 09:22 PM
Thanks Ill be checking em out.
tech69 09-27-2012 10:53 PM
also check out JamesFreddy on youtube, he has an awesome video on buffing. he's been trained well, is still humble enough to learn new things, and has his own procedures.
cutthroatkid 09-27-2012 11:08 PM
I like the sound of that someone who isn't stuck on his self Thanks
