Originally Posted by crashtech
I'm interested to see how this works on a complete vehicle. The catalog states that this product will remove 3000 grit scratches, but also says that it's "Ideal for spot/small repair areas", which indicates to me that you might be there for an extended period with the buffer.
Yea, I knew that when I bought this stuff but I wanted to avoid going to the wool Superbuff pads. I've had trouble in the past getting a few scratchs using wool pads although they were Schlegel brand not the 3M.
A few on this forum have indicated that using the foam pads results in no scratches. Is there an alternative to the Perfect-It III Machine Glaze that you think might work better?
Some more buffing time with the Machine Glaze wouldn't bother me as long as it doesn't turn out to be a P.I.T.A.
