Well, that's what I'm starting to do right now only with PPG Global DG Single Stage.
This is what I am planning on doing: 1. Block by hand with 1000 wet. 2. Block by hand with 1500 wet. 3. Use 3M Trizact 3000 foam pads on a DA wet. 4. Perfect-It III Machine Glaze (05930) with a polisher and 3M foam pad. 5. Perfect-It III Finishing Glaze (05941)with a DA and 3M foam pad. I have never done it this way before, so I hope it works well. All this stuff was outrageously expensive at the local Sherwin Williams store. Should have shopped around on the net for it. |
A few on this forum have indicated that using the foam pads results in no scratches. Is there an alternative to the Perfect-It III Machine Glaze that you think might work better? Some more buffing time with the Machine Glaze wouldn't bother me as long as it doesn't turn out to be a P.I.T.A. |
3M Perfect-It 3000 Rubbing Compound #6062 can be used with a wool or a foam pad, and is a bit more aggressive than the product you chose. It's what I would use for a complete job, since my back is not that good and I like to get done already!
Hey guys, thanks for the reply, and best of luck on your paint jobs.
I was looking to use the Presto line of products as they look good to me. http://www.prestaproducts.com/ I have never painted a Car before so this is my first cut at it. I shall try post pics when its complete. The Valspar Paint seems to set up very well and has got nice DOI even without cutting and buffing. My cut and buff will mainly be to remove the nice little dust particulas that I am sure will make there way into the paint Oh for a a real down draft spray booth !, like in mydreams. Thanks .... X |
| Paint choice? | daimon1054 | Body - Exterior | 2 | 10-29-2003 11:02 AM |
