Cut Coil Springs ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-06-2003, 12:48 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Yes, I understand. That is what I was referring to also.
  #17 (permalink)
Old 01-07-2003, 02:21 PM
Post
Just wanted to update I cut the springs with my angle grinder last night and the truck sits perfect! I cut off 1.5 coils as the June 77' issue of hotrodder mag sugested to and it now sits about 3/4in. high so I assume that it will settle and be perfect. Thanks for all the info all I believe the springs were 5/8 in. dia wire. Zach
  #18 (permalink)
Old 01-10-2003, 06:30 PM
PrimeMover's Avatar
Sittin' on top of the world...
Post
Back in the early 70's I used to do a lot of shocks on the early Mcphersons before they went to the OEM cartridge style shocks. Yank out the guts, dump out the oil, slide in a new set of Monro gas cartridges and crank down the new spanner nuts - "250 dollars, thank you very much." There's lots of available travel on this type of strut assy. I've never had occasin to slam one yet, but I'm sure it can be done. There really isn't much labor involved in tearing one down to find out. A new set of springs would be a cheap education if it doesn't work well. If you cut them, cut 'em on the bottom. That is where the spring end indexes into the pocket. As I recall, the top side that fits the upper spring bucket is flat with a poly cushion. I'd get a little more info. though, before I tore it up.. Mcpherson frontends have been around for a long time now. There's bound to be sombody out there who's 'slam smart' on the subject.
  #19 (permalink)
Old 01-10-2003, 07:10 PM
PrimeMover's Avatar
Post
zach - Woops! I posted a little late. I'm glad your happy with the way it turned out.
