cut down top modal A - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2007, 09:45 PM
ive got a 1930 modal A 2dr cp the top has been cut off any ideas on how to make it look right and stable? thanks Dean
Old 07-27-2007, 06:37 AM
cboy's Avatar
Last journal entry: Finished
If you have any digital pictures it might be helpful if you posted one or two so folks can get a better idea what you are working with.
To post a picture, first size it to approximately 4" tall x 6" wide and 100 dpi. Then, when you enter your next post, simiply scoll down on the edit screen until you see the "attach files" box and click on "Manage Attachments". Follow the directions to select the picture(s) you have. The software will upload them them as attachments at the end of your post.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 07-27-2007, 08:25 PM
Metal Twister's Avatar
Change is Opportunity!
Last journal entry: ( Chop Um-Up ) 1947 Plymouth Sedan Chop
Ive turned a 32 plymouth into a convertible, also a 28 Ford 2 door Sedan. Cboy is right, It would be a big help to see how and where it is cut off at.
Ive got some pics if it would apply?
Old 07-28-2007, 08:36 PM
cut down 30 model
thanks,ill get picture so you can see what iam trying to do.I bought this car in pieces so its been fun. thanks for writeing. Dean
Old 07-28-2007, 10:46 PM
on the 28 I just built a cap all the way around using the press brake and shrinker / strecher.
Ill post this one I built so you can see what to original body line looked like.
These pics were very early in the process. the door is slightly open it the one pic, thats why it looks a little off.
The plymouth coupe I had to make a little more room for the convertible top to fold down into the car. I had to slice and dice it back about 6".
Hope this helps some, pm me if i can be any further help. good luck, Bob
Old 07-29-2007, 12:43 PM
cut down coupe
thanks for your help. DEAN
Tip of the day #13 MARTINSR Body - Exterior 6 12-24-2005 03:09 PM
chopping the top on a metro Bad Rat Body - Exterior 40 12-16-2005 12:29 PM
convertible top vs. hard top billyr Body - Exterior 2 02-21-2004 06:48 PM
going convertible from a 4 dr hard top leamichael Body - Exterior 0 05-14-2002 06:50 PM
