Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cut, Fit, Grind, Fit, Weld, Grind, Repeat
Old 03-28-2004, 07:38 PM
Centerline Centerline is offline
Wiki Edits: 49
Smile Cut, Fit, Grind, Fit, Weld, Grind, Repeat
I've watched guys at muffler shops bend up custom exhaust systems many times but never tried to do it myself till today. With a box of mandrel bends, a saws-all, and my trusty Mig welder I started on the trucks exhaust. Spent all afternoon and managed to get both header pipes done from the exhaust manifolds back to the trans. I think I crawled under that truck about 40 times today. It's a labor intensive process but the hard part is done and the rest is pretty much a straight shot back to the rear end. Next time though I'm going to use a lift. My back will definitely appreciate it.
Centerline
