Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cut, Fit, Grind, Fit, Weld, Grind, Repeat
Old 03-28-2004, 06:59 PM
Weimer's Avatar
Weimer Weimer is offline
Kenneth Howard hates you...
Last journal entry: door pics smaller
CL....I am going to build my own exhaust on the S10, mainly because it has to be a very tight fit, and absolutely NOTHING can hang below the frame or to close to the cab floor.
Where did you get the box of bends at?
Thanks,
WEIMER
