Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cut, Fit, Grind, Fit, Weld, Grind, Repeat
Old 03-29-2004, 08:33 PM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
I have done a good bit of mandrel cut and fit exhaust. I actually love the work. It is fun to put it all together to me. It is more work than paying someone else but it is how I want it when I am done. I probably have 20 different pieces in the S10 crossover pipes and downpipes. Everyone requires tweaking, but you get better and better at it. I can eyeball most cuts close enough to make it work now......maybe just a little grinding
Anyway, I understand the work, but I like it...
Chris
