Cut, Fit, Grind, Fit, Weld, Grind, Repeat - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2004, 06:38 PM
Wiki Edits: 49
Smile Cut, Fit, Grind, Fit, Weld, Grind, Repeat
I've watched guys at muffler shops bend up custom exhaust systems many times but never tried to do it myself till today. With a box of mandrel bends, a saws-all, and my trusty Mig welder I started on the trucks exhaust. Spent all afternoon and managed to get both header pipes done from the exhaust manifolds back to the trans. I think I crawled under that truck about 40 times today. It's a labor intensive process but the hard part is done and the rest is pretty much a straight shot back to the rear end. Next time though I'm going to use a lift. My back will definitely appreciate it.
Centerline
Old 03-28-2004, 06:59 PM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
CL....I am going to build my own exhaust on the S10, mainly because it has to be a very tight fit, and absolutely NOTHING can hang below the frame or to close to the cab floor.
Where did you get the box of bends at?
Thanks,
WEIMER
Old 03-28-2004, 07:04 PM
badknuckles's Avatar
you talkin to me?
he know's where mr mandrel lives and lets just say that his garage door isn't always locked.
Old 03-28-2004, 08:32 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Yea Weimer I'm curious too, does anyone sell an assortment of bends that would be needed to do your own system? I could only find one exhaust shop that does mandrel bent systems in the Tri State area. I've got the tools and the time, I would save myself a small fortune doing the system on my project. Well maybe I'll leave bending the tail pipes up to a pro.
Mike
Edit: Seached after posting. http://store.summitracing.com/defaul...h&part=mandrel 3rd page
Old 03-28-2004, 08:49 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
i wanted to do my own exhaust, but out of mig gas, wire, and patience. i just wanted it done. so add exhaust to the list of things i did not do myself.
1. machine work on block.
2. laying out of the flames.
3. exhaust.
not bad for a rookie.
Centerline, does it look Kustom?
Old 03-28-2004, 08:59 PM
Ghetto Jet's Avatar
Whoa forget Summit, check this company out http://www.exhaustdepot.net/manben2to5.html nice selection, the stainless steel flex sections would come in handy too.
Mike
Old 03-28-2004, 09:24 PM
Weimer's Avatar
Summit -Box of Bends 10- 180 deg, 4- 120 deg, 4- 90 deg....$225
Exhaust Depot 10- 180 deg = $199.20
4- 90 deg =$ 62.00
4- 120 deg =$ 78.88
For a Grand Total of $340.08 + shipping
For that price I think that I would go with Summit on their bends. Besides Summit has free shipping.
I guess I'll just have to search a little harder for someone around here that has a mandrel bender OR have to deal with regular bends in the pipe.
Later,
WEIMER
Old 03-29-2004, 03:27 AM
New Member
I got my header pipes from summit... I'm going somewhere else though to get stainless bends next time I build a header.
Old 03-29-2004, 04:49 AM
Wiki Edits: 49
I had the same problem as the rest of you guys when it came to buying the tubing. But......... when all else fails JC Whitney to the rescue. I bought enough 90*, 45*, and 180* bends to to the entire dual system for about $100. I also bought a crossover pipe kit from Summit. I think it was about $40.
Whatever straight pipe I need I'll just pick up from a local muffler shop but I don't expect to spend over $200 total for the entire system including the turbo mufflers. (I bought a couple Hemi Challenger square chrome exhaust tips at a swap meet last year and I'm not counting what they cost me )
Centerline
Old 03-29-2004, 10:38 AM
k2mooch's Avatar
Yo Centerline, that's awesome. I've been under mine for the past few weeks trying to get a transmission in, so I don't think I'll have too much gripe about trying to piece together some tubes soon. You got any pics of it? I'd like to see how it turned out.
MoocH
Old 03-29-2004, 06:01 PM
38 special's Avatar
Be the MIRACLE!
Last journal entry: Running boards (part DUEX)
Weimer, as low as your truck is sitting you'll have to tunnel under the body for it not to drag.
Old 03-29-2004, 06:29 PM
Weimer's Avatar
I'm thinking about putting a basement in the garage just so I can park the truck in it LOL!
Later,
WEIMER
Old 03-29-2004, 06:53 PM
38 special's Avatar
Be the MIRACLE!
Lol! You don't need a basement if you have one of those big huge 4 x 4's you can just park right ovet the top of it.
Old 03-29-2004, 08:33 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
I have done a good bit of mandrel cut and fit exhaust. I actually love the work. It is fun to put it all together to me. It is more work than paying someone else but it is how I want it when I am done. I probably have 20 different pieces in the S10 crossover pipes and downpipes. Everyone requires tweaking, but you get better and better at it. I can eyeball most cuts close enough to make it work now......maybe just a little grinding
Anyway, I understand the work, but I like it...
Chris
