cut n buff finally - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2011, 03:57 PM
62galaxiguy's Avatar
cut n buff finally
I finally finished my 7 year resto project.I painted the 62 galaxie xl wimbledon white using ppg concept single stage.It came outreally clean,using my friends booth.I wet sanded using 3m 1000 grit by hand,then 1500 by hand(A lot of WORK!) but i was afraid to use a da.I think i will wetsand with 2000grit then buff using Presta ultra-cut cremeand a lake country twisted wool pad,then a white ccs foam pad and 1500 presta polish. im pysched.Did i miss anything?
Old 07-01-2011, 05:26 AM
Last journal entry: 50 Ply wagon
Get yourself a hand spray pump bottle and fill it with water. Then always spray the area with some water before doing the buffing. Keeping the area wet will also keep you from burning through the paint.
Also make sure you put some sort of covering on surrounding areas when you start buffing. The buffer will throw out drops of the buffing compound and if it is allowed to dry on surrounding surfaces, it may spot and not come off.
Old 07-01-2011, 06:34 AM
Dart is right on the money about covering other painted parts that have been cut 'N buffed. I use Presta products and have in the past used the other major brands. They all spot. Get a bundle of microfibre towels and wash them often, otherwise you may find your chasing your tail buffing out those spots.
Jim
Old Car Buff LIL DIGGAR Introduce Yourself 2 02-08-2009 04:15 PM
Why buff new BC/CC? 68NovaSS Body - Exterior 3 07-27-2007 06:02 AM
Old car buff Dooley10 Introduce Yourself 5 01-30-2007 01:41 AM
Have to buff flatford39 Body - Exterior 2 04-09-2006 08:46 PM
