To Cut Or Not To Cut - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-15-2010, 10:13 AM
deadbodyman's Avatar
Wiki Edits: 11
Originally Posted by Jim Rockford
buy a case of PB Blaster.. NOT wd-40
Whats the diference ,Jim? i know guys that use PB but I always went with WD,no reason,is it a lot better?
  #17 (permalink)
Old 04-16-2010, 06:34 AM
Will I ever get it done?
Last journal entry: Driver's Door
Check out my journal. I am doing a 41 two door sedan. Lot's of rust repair photos.
Then, start your own journal. The PJ's need two 41 Chebbie journals.
I will answer the question now. The reasons for the last entry being in November. First, we had a cold, wet winter. No heat, so no work. When it finally did get to the point where I could get out there, I went to step over a box and almost made it. Broke my ankle. Should get off the crutches today, but will have to wear the boot for another month. Don't think I will be welding with all this foam and Velcro on my right leg! I will probably start wiring the dash soon.
Last edited by redsdad; 04-16-2010 at 06:35 AM. Reason: Spell check is not stupid check.
  #18 (permalink)
Old 04-16-2010, 08:18 AM
Wiki Edits: 31
lots better.. it'll eat rust
Stuffing BBC into a little S10 S10 Racer Engine 6 08-06-2008 12:15 PM
what to cut unsulation with??? yragat Interior 5 05-05-2008 11:05 AM
Welding on Quarter Panels mightycarlo10 Body - Exterior 9 04-02-2008 09:16 AM
cut the rear 66stangrcr Body - Exterior 1 03-13-2006 08:13 PM
