drill the heads off of them
when taking apart old cars always tighten first then them back out.
Just went through this as was said get yourself a nice set of sharp bits and a good ***** punch and have at it. A cut of wheel will be quick but it will also make more work for you when you hit the fender,ask me how I know that Ll. Also I used some heat in places where it would not hurt anything and that worked ok too...
Thanks for the advice all... Shine, tightening first helped on some, but others just fell apart. I think I'll try drilling them. As you can see (if the pic loads) i dont plan on saving this fender.
heat and oil
I warm the hardware with the torch , squirt on some penetrating oil a few times. and use the hammer and the impact driver. I try to save as much as possible and give away what I won't need to someone who needs a patch panel. and sometimes burn and grind to get it apart.
You're going to need new bolts anyway. Oh ya. You're a brave man from what I see of your rust. |
Oh yes you ARE brave,and you've got a long road ahead of you.When I started my rust bucket I went around the whole car with wd-40 hitting every bolt then did it again a couple days later.90% of the bolts came right out even the ones that had heads rusted so much a scoket wouldnt work I had to use vise grips.impact drivers, heatsometimes hitting it sideways with a chisel and hammer is what it takes to loosen it up.grind as a last resort but dont be affraid to grind ...whatever it takes...on that old car you'll need lots of bolts anyways.looks like my 48 when I started. Good luck ...Look me up if you get in a slump...
LOL,it'll cost a whole lot more than that, buddy
But it'll be worth it...
I been there you gotta lotta kissin up ta do. She'll win out as far as what gets the most time and money.so find your parts cheap.you'll learn two handy little things .....
how to talk a deal and how to be a great kisser.... Just remember who's the boss.........and dont get upset when she puts her foot down.
buy a case of PB Blaster.. NOT wd-40
| Stuffing BBC into a little S10 | S10 Racer | Engine | 6 | 08-06-2008 12:15 PM |
| what to cut unsulation with??? | yragat | Interior | 5 | 05-05-2008 11:05 AM |
| Welding on Quarter Panels | mightycarlo10 | Body - Exterior | 9 | 04-02-2008 09:16 AM |
| cut the rear | 66stangrcr | Body - Exterior | 1 | 03-13-2006 08:13 PM |
