Cut-off disc warning - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2011, 10:45 AM
I was on another forum today and read a post from a guy who had just experienced something I have also seen. Apparently he had been using a cut-off disc on a 4 1/2" grinder and since the disc was already mounted on the grinder he attempted to grind a nub off of a spot weld with it and the disc disinterested. I myself have been guilty of doing this and also have experienced exploding discs which can be very dangerous, about 10 years ago in Ky a guy was very seriously injured when one exploded and hit him in the neck nearly killing him. Apparently these things are safe only for cutting with the edge and attempting to grind with one, even for only a very short time, is a very dangerous practice and should never be done. Personally I will never attempt it again since it takes only seconds to change to the right disc and the results from not doing so might be disastrous. Anyone else have thoughts on this?
Old 07-17-2011, 10:58 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Cut off wheels will explode if they are bound in a cut or subjected to side loads. The guy most subject to this is the guy who only has one 4" grinder and is in a hurry. Those small grinders are cheap enough to have more than one and each one with its own type of wheel on it. Plus it is a lot more convenient to have those little grinders available with the proper wheels for each type of grinding..
Sam
Old 07-17-2011, 11:00 AM
Wiki Edits: 31
I did it once, and the disc started to come apart very quickly. There quick enough to change, even if you have only 1 grinder ( like me )
Old 07-17-2011, 11:56 AM
Yeah. DON'T DO IT. As noted, these disks are NOT designed for side loads. To use them that way is evolution in action.
Old 07-17-2011, 12:59 PM
302 Z28's Avatar
Use what is called a "flap disc" for that.
Vince
Old 07-17-2011, 01:12 PM
Originally Posted by 302 Z28
Use what is called a "flap disc" for that.Vince
The flap disc, IMO the best thing to happen to grinding since the invention of electric grinders! I keep a bunch of those things on hand in different grits and every time I place an order at Enco I always add a few more.
Old 07-17-2011, 03:10 PM
Last journal entry: How I repaired '51 door hinges
This is not intended to stray from the subject at hand. I have seen this used at other posts. What does "IMO" mean?
4Chuck
Old 07-17-2011, 03:24 PM
Joe G's Avatar
4Chuck
It means "In My Opinion" sometimes you'll also see IMHO which is "In My Humble Opinion".
Old 07-17-2011, 03:26 PM
IMO it means "In My Opinion".
Old 07-17-2011, 04:22 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i think there is a big difference in quality of disc - and it will make a big difference how much side load they can take.
i dont buy the cheapies and they seem to hold up pretty well
i only use the tip of the wheel when grinding on side edge ( not the middle creating a weak spot in the middle )
Old 07-17-2011, 04:35 PM
cut off wheel
I have had the same experience and I left the half of the wheel yhay stuck in my shps wall insulation ther to remind me to use the right tool for the job!
Old 07-17-2011, 05:03 PM
life is a temporary assignment
They are called a ''CUT OFF WHEEL'' for a reason.. NOT !!! A grinding wheel.. Remember when working with ''ANY'' POWER TOOL... you have to be smarter then the tool your using..... Do your grinding with what is made for grinding..... It's real easy to understand..
You play with a snake long enough,, And you just might get a snake bit..
Old 07-18-2011, 12:09 AM
ScojoDak's Avatar
Mopar for life!
And wear a face shield!
Old 07-18-2011, 04:02 AM
willowbilly3's Avatar
Last journal entry: Body mods
I own at least 6 grinders so I never have to change discs. I use my cut off almost every day. I also keep a couple handy with grinding wheels and flap wheels and one with a wire brush that I hate and rarely use.
Old 07-18-2011, 06:36 AM
Irelands child's Avatar
About what I have - one has a cut off wheel, another Rol-Locs, the bigger electric has a grinding wheel, the fourth flap and on up the scale.
I have had a couple of the 1/16 or 1/32 cut off wheels break up - man does that stuff fly - but so far no damage to self or part. I always wear goggles or face shield
If do I drop a grinder with one of those 1/16 or 1/32 wheels on it, that wheel is removed, broken in half and thrown away so it can never be retrieved and used again. I've found that just like a piece of buttered bread that if you drop it, it always lands to do the most damage.
Dave W
Irelands child
Warning Ripoff. Fraud. Warning 71gtx Hotrodders' Lounge 22 09-09-2011 11:09 PM
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 10:38 AM
1965 Impala disc/disc freedom53 Suspension - Brakes - Steering 1 11-06-2007 10:02 PM
Disc/Disc vs Disc/Drum master cylinders rlvirago Suspension - Brakes - Steering 6 02-28-2007 04:33 AM
Can a guy use a disc/disc master with drum rear? MM in NM Suspension - Brakes - Steering 1 12-08-2005 06:08 PM
