-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   cut off tool (http://www.hotrodders.com/forum/cut-off-tool-149257.html)
jasrking 12-05-2008 10:36 AM
cut off tool
1 Attachment(s)
Does anyone know where I can find an electric cut off wheel. Just like the picture but electric.
burnt olds 12-05-2008 12:39 PM
cut off tool
well you can use a 4 inch grinder and buy the thin wheels for them , but you need a spacer , i have doubled the backing washer or a big flat washer to make up the difference .
but beware , use the guard for sure and safty shield with safty glasses behind them .and gloves .
forestrytodd 12-05-2008 12:50 PM
I've got an arbor that I use on my 4 1/2 inch angle grinder like burnt olds is talking about but mine does not require a spacer. It is 2 pieces that sanwich the disc between them. works great! Got mine at Northorn Tool
OneMoreTime 12-05-2008 02:18 PM
On mine i can just turn the arbor nut over and it works fine..buy the wheels in the industrial size boxes as one can go thru those things fairly fast and they are cheaper that way..and I have some when I need them and do not have to run to the store all the time..
Sam
jaguarxk120 12-05-2008 04:59 PM
I've been using a Makieta electric die grinder. With a arbor mounted cutoff wheel it works just like the air driven one. Nice thing about it is now I do not have to fire up the compressor just to make one or two cuts.
boatbob2 12-05-2008 06:55 PM
cut off tool.....
hi,i have 2 --4 inch angle grinders,a makita and a bosch,i buy the 4 1/2 inch cut off discs at harbor freight,about $5.00 for a pack of 10. they work great,and at a good price,BUT,beware of buying electric tools from harbor freight.
NEW INTERIORS 12-05-2008 07:49 PM
You can get the 4.5 cut off blades on sale from HF a pack of 10 For like $3.50 or so.Don't remember what it was.But I stack up when they are that price.I use them a lot. :thumbup:
They are $5.99 for a pack of 10 now,
NEW INTERIORS 12-05-2008 08:29 PM
I have also used the 4.5 Masonry cut off blade's on metal,I don't find any difference between the masonry or the metal blade's,to me they cut the same. :)
jsaw 12-05-2008 08:40 PM
Milwaukee
1 Attachment(s)
I have both air powered, & electric powered, In lots of ways, the electric one is handier. It is a Milwaukee
59 wagon man 12-05-2008 10:14 PM
roto zip at home depot or lowe's comes in a kit with all kinds of different ends and cutting wheels
metalmeltr 12-07-2008 05:47 AM
ingorsoll rand makes a cordless one
MrPhotographer06 12-07-2008 07:51 AM
harbor freight...
