cut off tool - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2008, 10:36 AM
cut off tool
Does anyone know where I can find an electric cut off wheel. Just like the picture but electric.
Old 12-05-2008, 12:39 PM
cut off tool
well you can use a 4 inch grinder and buy the thin wheels for them , but you need a spacer , i have doubled the backing washer or a big flat washer to make up the difference .
but beware , use the guard for sure and safty shield with safty glasses behind them .and gloves .
Old 12-05-2008, 12:50 PM
forestrytodd's Avatar
Official Hotrod Forester
I've got an arbor that I use on my 4 1/2 inch angle grinder like burnt olds is talking about but mine does not require a spacer. It is 2 pieces that sanwich the disc between them. works great! Got mine at Northorn Tool
Old 12-05-2008, 02:18 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
On mine i can just turn the arbor nut over and it works fine..buy the wheels in the industrial size boxes as one can go thru those things fairly fast and they are cheaper that way..and I have some when I need them and do not have to run to the store all the time..
Sam
Old 12-05-2008, 04:59 PM
I've been using a Makieta electric die grinder. With a arbor mounted cutoff wheel it works just like the air driven one. Nice thing about it is now I do not have to fire up the compressor just to make one or two cuts.
Old 12-05-2008, 06:55 PM
boatbob2
cut off tool.....
hi,i have 2 --4 inch angle grinders,a makita and a bosch,i buy the 4 1/2 inch cut off discs at harbor freight,about $5.00 for a pack of 10. they work great,and at a good price,BUT,beware of buying electric tools from harbor freight.
Old 12-05-2008, 07:49 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
You can get the 4.5 cut off blades on sale from HF a pack of 10 For like $3.50 or so.Don't remember what it was.But I stack up when they are that price.I use them a lot.
They are $5.99 for a pack of 10 now,
Old 12-05-2008, 08:29 PM
I have also used the 4.5 Masonry cut off blade's on metal,I don't find any difference between the masonry or the metal blade's,to me they cut the same.
Old 12-05-2008, 08:40 PM
Milwaukee
I have both air powered, & electric powered, In lots of ways, the electric one is handier. It is a Milwaukee
Old 12-05-2008, 10:14 PM
59 wagon man's Avatar
roto zip at home depot or lowe's comes in a kit with all kinds of different ends and cutting wheels
Old 12-07-2008, 05:47 AM
ingorsoll rand makes a cordless one
Old 12-07-2008, 07:51 AM
MrPhotographer06's Avatar
Krazy Kid
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
harbor freight...
Piston notching for valve relief/clearance OHD Engine 9 09-16-2008 10:27 AM
Chop and channeling. how to....? baugh353 Body - Exterior 15 02-07-2006 07:21 AM
What's the difference between a die grinder & a cut off tool? FrankR Body - Exterior 20 12-15-2005 05:40 PM
Question about removing roof 86caprirs Body - Exterior 3 03-27-2005 12:21 PM
