cut the rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2006, 05:46 PM
cut the rear
hi i have a 66 mustang i wanted to put some 17 x 10.5 rims in the back but im noticing i have no room the back i figured i would have to cut i need sug should i cut? should i get smaller rims? if i do cut what do i do i need people.
Old 03-13-2006, 08:13 PM
30desoto's Avatar
Dodge ain't all bad
66stang
First off-- don't cut that car up!!!!!!!!!!!!!!
Second go with thinner wheels maybe 8", do you really need 17" wheels or just like the looks of them??????
You can't just cut up your car to put bigger tires and wheels under it unless you want it to look like S%^$#$^&*T. excuss my language. You could get your rearend shortend and tub the inside of the trunk, but thats not a five min. job.
You do what you want it is your car but I don't believe anyone here is going to tell you to cut your car up for a bigger set of wheels, but who knows I am not always right.
30dee
Tip of the day #13 MARTINSR Body - Exterior 6 12-24-2005 03:09 PM
79 trans am rear discs busterbuddie Suspension - Brakes - Steering 2 01-10-2005 06:29 PM
Rear end identification help 71gtx Transmission - Rearend 1 11-07-2003 07:14 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
