Cut thru to fiberglass? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2009, 07:40 PM
I was stripping my trans am hood. I stripped as much as I could then I hit it with 80grit on the DA then 120grit on DA. It went from black, to grey to white. I'm guessing I hit the fiberglass/gelcoat. Is there anything I have to do in order to epoxy this now or am I good and just spray it? thanks.
How to mold fiberglass? Slimpikins Body - Exterior 12 05-19-2008 02:08 PM
Sanding the *%^$&# primer all off the fiberglass parts Ripped Body - Exterior 7 09-01-2007 07:56 PM
fiberglass to fiberglass scoop bluebu Body - Exterior 62 06-23-2005 05:15 PM
Fiberglass fenders jcclark Body - Exterior 4 06-16-2005 06:25 PM
Fiberglass Hood & Fresh Air T7SuperBee Body - Exterior 7 06-01-2005 04:40 PM
