Cut Wire - Where should it go?? 92 S10 Blazer - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2009, 12:54 PM
klutchmaster427's Avatar
Last wiki edit: Automobile body and frame rotisserie
Last journal entry: Bell Crank Fix
Wiki Edits: 4
I've got a 92 S10 Blazer, and I've been having some problems with the 4WD so I was checking out the actuator under the battery and found an open vacuum line. The vacuum line goes to an electrical connector of some sort, from which a pair of wires run to the firewall, then along the firewall to a grouping of wires near the brake booster. From there, it splits into two sets of wires. The first set goes to the front differential. The other set has two wires coming out of it. There first wire goes through the firewall. The other is a little black wire that goes to another connector. from that connector comes an identical little black that has somehow been cut. its really rough, so it was cut by pliers, its been torn or broken somehow.
What is this wire for and where does it go????
I attached some pictures so you can see where it goes and what it looks like. Thanks!
Name:	01 - open vacuum line.jpg
ID:	41147   Click image for larger version
Name:	02 - closeup of connector.jpg
ID:	41148   Click image for larger version
Name:	03 - tracing wire 1.jpg
ID:	41150   Click image for larger version
Name:	04 - tracing wire - (connectors).jpg
ID:	41151   Click image for larger version
Name:	05 - tracing wire - (little black wire).jpg
Old 10-23-2009, 02:20 PM
sedan delivery's Avatar
wiring
when i have a wiring problem i cant figure out i go to Autozone web sight ,,there you can fill out your information and click on repair section and click on wiring diagrams. you can scroll on each diagram check the year of each diagram and click on the diagram to enlarge.good luck
Old 10-24-2009, 03:29 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Isn't the same wire shown left of the pink/blk stripe wire at the bottom of the connector in the attached image?
Old 10-27-2009, 10:45 PM
fast68's Avatar
likes chevy trucks & boobies
hmm interesting in my 92 s10 that black white stripe connector single wire isnt even connected to anything
the only thing that doesnt work in mine is the cruise control
odd..
on yours the one that is stripped or whatever in bad condition is the one mine doesnt even have at all
connector end on it going towards the main harness by the booster is intact though.,
Old 10-28-2009, 09:08 AM
Wiki Edits: 4
weird. im not sure if the cruise control works or not. my wife never uses it. ill have to try it! lol
Old 10-28-2009, 12:08 PM
fast68's Avatar
yeah im curious to know.
because ive given up on trying to figure out why mine doesnt work, but i need it badly because i highway drive often.. ive tried a new brake switch, checked vacuum in the hose, checked fuses and connectors, etc.
and the only thing not connected on mine is this small black white strip connector wire.
haha
good luck
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 01:04 PM
92 blazer make over jibbs0324 Introduce Yourself 1 03-12-2007 05:52 PM
92 blazer make over jibbs0324 Introduce Yourself 1 03-12-2007 05:51 PM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 05:22 PM
