Cut Wrong Wires - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2005, 01:27 PM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
Cut Wrong Wires
Hi, I have an 1989 Chevy Silverado which I removed the stock 305 in favour of a 350 non computerized engine, so i'm not using the computer.
The original wiring harness had alot of wires coming from the passenger side of the engine compartment to all the engine sensors that I don't need any more. So I cut them and now I have no headlights, no interior lights. Tail lights are OK
Any one?
Old 07-23-2005, 01:40 PM
sedan delivery's Avatar
wire problems
hope you didn't remove the harness going into the veh. if it is still in place you can check the colors and match them up and resolder them. if this is not going to work you can tie in to the wires to the head lights and run them into the inside and connect them to the dimmer switch. you may need some wire diagrams to help. you can go on line to auto zone fill your current veh. and click repair information and follow the pages to wiring. there will be more them one page of diagrams. or you may follow suggestions from others who will tell you have to order an after market harness.
Best Spark Plug Wires?? HotRodMan Engine 17 09-27-2005 12:09 AM
ford c6 neutral safety wires cboy Electrical 1 02-11-2004 05:18 PM
EZ-Wire : Reading Wires From Steering Column horvath Electrical 2 03-23-2003 04:56 AM
i got wires running everywhere jtp060482 Electrical 2 01-05-2003 12:46 PM
