Originally Posted by jimfulco
An Olds 455 is bigger externally than an Olds 350. Motor mounts are in the same position, but the deck is higher on the 455. Pontiacs are the ones that are the same size.
Yep and I wouldn't be so quick to ditch the Olds 350, couple of my friends had them back in the day. One was a factory Hi Perf piece and the other was built up from a base 2 bbl. engine both were in '68 Cutlass Hdtps. with 3.90 gears, one was a 2 speed automatic ( Olds called it a Super Turbine 300 not a Powerglide IIRC ) and the other a 4 speed and they were both very strong runners. For serious performance work the earlier 330 had the same stroke and journal sizes and used a forged steel crank. The later Olds 403 is the same deck height and has the best rods plus there is a ton of performance goodies available for the "short deck" Olds motors. Same performance parts for a Pontiac 400 will fit the 350 except pistons but the 400's were so easy to find that most people didn't mess with the 350's but they can pack a wallup too. All 4 of the GM 350's had performance potential but the B-O-P 350's were overshadowed by their 400 CID and larger siblings.
