cutlass supreme 81 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2012, 11:38 AM
cutlass supreme 81
I have a 81 cutlass supreme with a 30t5 engine and was wondering what kind of transmission I could put on it
Old 04-03-2012, 08:05 PM
GMCBEAST's Avatar
With some mod's you can put just about any GM trans in that car. What is the primary use of the vehicle? If it's a fairly stock daily driver I'd put the same trans in it that it originally had to save you some headaches. Things to think about are driveshaft length, yoke splines and crossmember placement if you decide to swap to a different trans than you originally had.
Old 04-04-2012, 04:39 AM
Are you sure it's a 305 Chevy and not a 307 Olds motor? They have different bellhousing bolt patterns. Both are listed as 5.0 liter motors.
Old 04-04-2012, 05:14 AM
well
Old 04-04-2012, 07:12 PM
Trans
over the weekend.I just put a 350 engine and.transmission
sbc with th 350 in 88 cutlass supreme? s : Danny1986 Hotrodding Basics 4 05-25-2011 03:31 PM
what can I put in my 84 cutlass supreme 84cutty Engine 28 06-29-2010 08:21 AM
Cutlass Supreme????? greasemonkey92 Suspension - Brakes - Steering 9 11-06-2007 04:02 PM
Cutlass Supreme HP? greasemonkey92 Engine 1 01-13-2003 09:37 AM
305 Cutlass Supreme greasemonkey92 Engine 3 10-03-2002 07:50 PM
